Re:CHNC-1 Retrofit & Upgrades
14 years 3 months ago - 14 years 3 months ago #21779 by Alloy Craft
Looks pretty smooth, very nice. With all that work you did to get the turret servo on there, I was hoping to see the turret index. Anyway where did you get the pulleys and belts for the axis drives? Also what Mesa cards are you using on this one?
Last edit: 14 years 3 months ago by Alloy Craft. Reason: wrong question
14 years 3 months ago #21791 by bobinater
Hey rob
How much different is the chnc from the hnc other than the enclosure ?
Your machine is very impressive, love the coolant. and is it set up for constant surface speed?
14 years 3 months ago #21798 by robh
Replied by robh on topic Re:CHNC-1 Retrofit & Upgrades
this is one thing i do keep meaning to make a video off
but as CHNC is used for 2nd opp work 99% of the time, i never realy have a good video to make of turret index's as we allways gang up 2 or more tools on the square turret you see.
but turret is working perfect, it does realy want a new gear in there tho. to make it truly zero backlash on the worm and 3 gears..
we are so bussy tho we dont realy have time or urgent need for it. only thing we need to fix is the collet coloser as that thing just eats air now. looking to put a new hydrolic unit on.
rob
14 years 3 months ago #21800 by robh
bobinater wrote:
Hey rob
hi
the main difference is the 16C collets over the 5C collets..
a HNC is grate machine for 2nd opps and small parts.. the CHNC is also but for us not very offten we find we need the 16C size range.. as 5C would cover 80% of work gets put on it.
travels are the same on X and Y, some dont have the top parting slide with them but they both take same unit, its just Air over hydrolic tho so it eats air and can be a pain if not used for awhile, we very rarly use outs beacsue of that.
yes
constant surface speed, Rigid tapping, etc etc
anything EMC can do it can do and more.
rob
14 years 3 months ago #21812 by bobinater
thanks rob
My lathe does have the parts catcher and the air powered parting tool as well as the octagon shaped turret
It appears that all of the air valves are electrically actuated so I am not sure weather all of the air components are even working
it would probably be a good idea to make sure all of this equipment works before attempting a retrofit? Wouldn't you think?
Bob
14 years 3 months ago #21816 by robh
well in turth i pulled all mine out and replaced with new valves only as some of the macy ones had died before and here u can not buy them so i went with something off the shelf in UK.
as i had some already replaced when it was on old control i just wanted to tidy it all up etc...
most are 110V but afew are 24V i think turret up and turret lockpin/cousin are 24v ones
hardinge manuals dont give u too much info on CHNC so its abit of a figure it out as you go.
forthe HNC iv not chceked the manual
rob
Time to create page: 0.391 seconds
