- Thank you received: 5334
I don't think so. It will wait until spindle-ar-speed is true before starting motion, but I don't think it stops motion if it goes false.jd896 wrote: for now im wanting to have it so if the arc stops for any reason the machine will pause and for some reason im thinking ive read somewhere that if i wire the arc ok signal to the spindle is at speed pin that it will pause motion if this signal is lost ?
Yes, and in fact you _could_ consider, with the latest LinuxCNC, making M3 and M5 into g-code subs with the "remap" feature.if this is so am i right in thinking that in my o words i can swap the g64 and g65's for m5's and m3's
If it is read in a G-code, then use the analogue inputs (M66). If you want it in a bash scrip then halcmd getp pyvcp.pin-name should work.also on a side note how do i pass a variable from an on screen spin box to a o word ?
