- Thank you received: 240
Give it a try and see if it cuts properly.
If so you can add things back until it errors and you will get a good idea what is causing problems.
How does the hole size compare to what is being requested? I could imagine what you see being due to machine flex. (especially if the Z rocks during a plunge)
Tangential arc lead-in moves would be nicer.
Fredasiong wrote: Hi,
This is my machine:
K2cnc capable of cutting 13" x 25" with 296 oz of stepper motors and a porter cable router .See attached photos.
software by Cut2d.
