Fanuc servo drive integration
14 years 2 months ago - 14 years 2 months ago #23807 by PCW
The alarm bits are just a 4 bit code(codes are listed in one of the controller manuals), This would require tri-stateable differential drivers on those PWM pins (and knowing when to change dir: DRDY?)
Last edit: 14 years 2 months ago by PCW.
14 years 2 months ago #23816 by sivaraj
Yes 6-PWMs signals for 6 transistors on the 3phase bridge.
I worked on this about a year back .So If I remember right,the alarm signals are just multiplexed digital signals.No other protocal involved.
10 years 11 months ago #64632 by MANOLOMARAVILLAS
hello i am again. s700 have a Fanuc robot, buy blcd picosystem converters. I also have these drivers.
and according to my research are these,,,,,
I share all my data,
image valid for::
a06b-6058-h221
a06b-6058-h222
a06b-6058-h012
a06b-6058-h006
10 years 11 months ago #64636 by MANOLOMARAVILLAS
pwm a .....pwmf is pwm control 6 trifasic mosfets...
drdy- servo ready
mcon:mcc , activated relay power 200va in mosfets control.(voltaje power start )
ir and is,,,,,, sending to control amp power windings motor....
10 years 11 months ago #64638 by andypugh
Welcome to the forum.
Are you adding information to this thread (Which is rather old) for future reference? In that case, thank you.
Or, do you have some questions?
10 years 11 months ago #64656 by jmelson
These Fanuc servo amplifiers require SIX PWM signals for each axis. If you have 5 motors on the robot (typical) then you would need THIRTY fast PWM channels to drive the 5 axes. Also, the top and bottom transistor of each pair must never be on at the same time, or it will likely blow the transistors. It might be better to just use 3 PWM generators with a pair of deadtime generators each to produce the 6 transistor drive signals. This would get into custom FPGA development.
Jon
Time to create page: 0.381 seconds
