Cincinnati Lathe-new project
- JR1050
- Thank you received: 33
26 Dec 2012 04:46 - 26 Dec 2012 04:53 #28034
by JR1050
Replied by JR1050 on topic Cincinnati Lathe-new project
Ive been workn on the Cinci in my spare time over the last month.The machine uses a5i25/7i77 combo with a opto g416i rack to control the AC outputs(this rack can be run in positive true logic).The control panel was rewired and connected to a 7i84 and IT WORKS REAL GOOD, a snap to set up.
The machine has a 12 station bi directional duplimatic turret and a 20hp Hitachi spindle drive.The original Siemens axis drives will be retained for as long as they work..The drives are ac with tachs,so they use velocity feed back and are much easier to tune the current mode amps.All the machine logic is written in C.Advice for any one using a BCD encoder for counting tool positions,if at all possible use a parity bit to confirm where you are.It is VERY easy to get a race condition from tool to tool.
Not my best video...the machine needs a good cleaning/derusting.It has been sitting unused for 5 years in the Fl humidity,my shop slave has some scotchbriting to do...
Last edit: 26 Dec 2012 04:53 by JR1050. Reason: neede to fix last sentence
- BigJohnT
- Thank you received: 1175
26 Dec 2012 05:24 #28035
by BigJohnT
Replied by BigJohnT on topic Cincinnati Lathe-new project
Looking good!
All you need now is some ngcgui tabs and your complete.
- Thank you received: 5035
26 Dec 2012 07:50 #28036
Replied by PCW on topic Cincinnati Lathe-new project
I should mention that if you have a lot of AC I/O, a 7I69 will make wiring to module racks easier by using standard 24 I/O 50 pin TTL driven racks.
Time to create page: 0.426 seconds
