TRAC DPM Conversion
24 Jan 2013 01:46 #29035 by Jarard
TRAC DPM Conversion was created by Jarard
I am considering converting our TRAC DPM with A.G.E. 3 controller to LinuxCNC. I have basic schematics of the wiring but very little info on the servos. I have removed one servo controller and attached a photo. Any help identifying these servos and how I should proceed is appreciated.
24 Jan 2013 02:15 #29037 by PCW
Replied by PCW on topic TRAC DPM Conversion
Do the schematics show what signals go to the motor drives?
Also a servo drive part number _might_ help though these dont seem very common
24 Jan 2013 02:38 #29038 by Jarard
Replied by Jarard on topic TRAC DPM Conversion
All the manual shows is 5 VDC and 115 VAC to the motors.
There are two part numbers for the motors X&Y servos are 20201, Z is 20327-2
24 Jan 2013 04:10 #29042 by jaredts
Replied by jaredts on topic TRAC DPM Conversion
Check out this link:
Looks like there is some information here that could help you.
-Jared
The following user(s) said Thank You: Jarard
24 Jan 2013 05:20 #29044 by Jarard
Thank you that link was very helpful.
So what I know of the pinout on the encoder is as follows
1 - PWM - 0-5V
2 - PWM - 0-5V
3 - Neutral
4 - ? - I can only read "S" on the board
5 - +5V
I would think it should be fairly easy to determine which PWM pin is the signal and which is the feed back.
24 Jan 2013 06:27 #29045 by PCW
Are you sure that is not just a standard quadarture encoder
1 - PWM - 0-5V A?
2 - PWM - 0-5V B?
3 - Neutral GND
4 - ? - I can only read "S" on the board INDEX?
5 - +5V
24 Jan 2013 21:59 #29088 by Jarard
Can you point me to a case study using this type encoder with DC drives or recommend the cards I will require.
25 Jan 2013 05:24 #29105 by PCW
There are many (1000's) of LinuxCNC retrofits to DC and AC servo machines but its still not clear what encoder types and drive types you have.
As a first step, I would check the signals from the encoders with a voltmeter to see if they are TTL square wave (likely quadrature) or perhaps analog sine/cosine.
The motor drive _looks_ like a analog input servo drive but its pretty hard to tell without more information
31 Jan 2013 00:14 #29316 by Jarard
Best I could do is measure the voltage of the signal during a jog. The multi-meter I have is limited so I took measurements using both the DC and AC settings as follows:
Slow jog: DC 2.4V AC 2.45V
Fast jog: DC 1.76V AC 1.67V
Not sure how to determine the type of wave without a scope.
31 Jan 2013 00:35 #29319 by PCW
Can you measure the signals when stopped? that would be more valuable
Time to create page: 0.097 seconds
