canner wrote: I only had time to solder in the resistors and check it out a little bit. With the resistors in and the spindle turning, I was getting about 4.5v on the signal wires.
canner wrote: It worked, what great news. I feel comfortable saying something is wrong with the original encoder, I just don't know what.
andypugh wrote: It was quite an expensive one, is it worth returning it?
canner wrote: Well in the time since I last wrote this lathe has been used to turn a thread, thank you so much for the help. I was struggling to hit a consistent od and id of parts and started looking at the cross slide. There is an extra 5 thou. of slop in the x axis then several years ago when I first set up the machine and so I will be pulling the cross slide of to see what is happening. I really don't think this is in the ball screw but we'll see.
