I don't know of any cheap and good ways to read resolvers. Both Mesa and Pico make good solutions, and I am using the Mesa card on my own machine. It only works with the N x 50pin Mesa PCI cards. (5i20, 5i23. Not the 5i25).canner wrote: I read a few threads on here concerning wiring in resolvers and then the Hal files to make it work. First I am going to check the resolvers to see if they are still good. I could change them to encoders easily but don't want to spend the money if I don't need to,
canner wrote: I am working on this machine again and have a question about the stepper motor drivers. The current drivers are microkinetics dr8010. I have not been able to find the information on these drives that I will need for setting them up with linuxcnc (stepon time and such). I have called the company and emailed them as well without getting an answer. if someone know that the timing requirements are for these drives that would be great. If not should I look for replacements or is there another way to figure this information out..
