Fanuc Robodrill AlphaT10C -- Retrofit -- Help
- prashant
No, it means that you need to use something faster than a PC parallel port to count the pulses that the Pico encoder converter sends out. Something like the Pico servo controller seems ideal...
Jmelson wrote:
Right, the converter's lowest rate of quadrature output is 500 K counts/second. So, you can't count that with software. It would not make sense to try to count a 64K count/rev encoder at low rates, the PID would get so far behind the actual position.
Ok! So this is how it will work for me?
PC --> Universal PWM Servo Controller --> PWM Servo Amplifier --> fanuc motor --> fanuc encoder --> Fanuc Encoder Converter --> Universal PWM Servo Controller --> PC
What about power supply? and spinde / spindle drive? can i use my current one.
Also, now that we know the requirment. May i get a formal Quotation for the complete Controller box with all internal wiring done. ( i have very less exprience and dont want to take the risk of connecting these parts at my end)
one more thing i am confused about is the mesa hardware. Where does it comes into picture? And why are we (PICO) using a paraport to connect pc to servo controller?
like the mesa 5I25 uses PCI Superport. What is the difference?
Prashant
- jmelson
- Thank you received: 160
Yes, that is how it works.
Possibly. Our servo amplifiers would need about 100 - 120 V DC to run these motors.
No, I don't make these complete systems. It is just too difficult, as every unit is different,
and I have to design a box to suit that one customer. I do have sample wiring diagrams
online.
If you use the Pico Systems hardware, you would not need any Mesa parts. If you were to use Mesa,one more thing i am confused about is the mesa hardware. Where does it comes into picture? And why are we (PICO) using a paraport to connect pc to servo controller?
you would not need any Pico Systems parts. The PC parallel port is a simple communications channel
that has been around a long time. It permits 1.5 megabyte/second communication between the
PC and the attached device. It also means you don't have to open up the PC, avoids occasional
problems with plug-n-play enumeration, and provides some isolation between the PC and the
machine tool. (Not to say it is galvanically isolated, it is not.) PCs are now moving to PCI-E,
but the parallel port remains. Yes, the PCI is faster, but the parallel port works for these
type of controls.
Jon
