Light Machine Corp. Benchman XTr (retrofit)
9 years 10 months ago #84096 by TGTROPIC
Rex,
I think schematic is attached....
TG
The following user(s) said Thank You: MacGalempsy, cncamateur
9 years 10 months ago #84108 by steve_a
Wow TG TROPIC. This is impressive! Got any other schematics? Looks like you can check a lot by just looking at the board. The power supply LEDs are LED 1-5 Are those all lit?
9 years 10 months ago #84111 by TGTROPIC
Steve,Yep...looks like pretty much EVERYTHING doesnt it.
We have had the machines about 10 years and JUST got these about 1 month ago.
anyways, 1-5 all lit.
TG
9 years 10 months ago #84126 by steve_a
Too bad... a missing power supply would have explained all the symptoms. I assume they are still the same. Just to clarify, can you move the table and z axis before you try to run the spindle? and are any other LEDs lit? Just trying to see what might be deliberate for safety and what is an actual error. AND there's a BIG "Uhoh".... looking at page 6, there are all the spindle control signals. They come from the J1 connector and go to the J35. The J35, I assume, goes to the spindle speed controller, which the sheets say is an EMS Speed controller for 45K Spindle. Mine is a 5K machine so I can't help you with that one. The "Uhoh" is because J1 is from that Nextmove Card in the computer. That's a $1000 board if you can find it. It was the reason my machine originally crashed before I bought it. You could try swapping the computer with one of the working units, but the risk is taking out a working card if whatever caused the original card to die is still present. I wouldn't do it. I could still be something on the control board but the Nextmove card is notorious for dying.
Anyway, its hard to say what is the issue. Someone with a 45K might have a way to test the EMS speed controller.
9 years 10 months ago #84130 by dynamyte24
TG,
Thanx a TON for the schematics. I have had no luck getting anything other than, "We no longer support that machine!",
from my phone and email contacts with Intellitek.
Do any of your machines have a 4th axis?
In all of the searching I have done, mine is the only one I've seen with the cabinet extensions to accommodate the
longer table and increased X axis travel.
Rex
9 years 10 months ago #84160 by TGTROPIC
Rex,
they did help for a while but has taken MONTHS to get to the point where they finally threw up hands, sent schematics and said " here you try to fix". Machines were purchase new and within 2 years the rep had dropped them so we have been dealing with Intelitek for about 8 years with slow, occasional assistance. it helps that I have names and direct contact numbers to blow up email and VM but they are not real quick in responding.
we do not have a 4th machine I have never actually seen one live.
Time to create page: 0.172 seconds
