Steve,
I am not able to send pics from my phone and did not bring camera so I will do my best to describe what I see.
J9 has 3 terminals with Y/G, BK and WH wires.The BK goes to the center of the machine near the large donut coils into the bottom LH terminal, along with a different Y/G wire, of a square block with 4 spade terminals potted into place...Fuse?...Ohms about 3.8 across legs.
The white goes into the smaller coil then WH out to lower RH spade on block.
The upper RH spade has a tan wire to the larger coil and then another tan wire from the large coil is attached to the upper LH spade. Coming from the large coil are 4 wires; WH,Y,O,Grey to plug J3 on the bottom of the main board.
TAN(lg coil) TAN(lg Coil)
BK/GR(J9) WH(sm coil)
There is no voltage AC or DC on any of the 4 wires or terminals with the machine powered.
Drive Pilot Light? Full wavwe Rectifier?
TG
