After reading thru this forum post again, I realized why it has been such a PITA to tune these servo drives. The servo power supply is unregulated!! Steve_a did the easy thing and replaced the toroidal xformer with a regulated PSU. However, not wanting to spend the money on a PSU that would not fit inside the case, I was able to use the schematic that someone posted. Attached is a reworked schematic to use the existing setup, and come off plug J9. Unfortunately, somewhere along the way, the original board came up missing, so I could not pirate the board for the components. However, Mouser has everything needed to make a new board, which comes in a little under $50. If someone who is a little more electronics savy could take a look at the attached document and help me out with the wattages for R37/R23 and specs on D26, it would be much appreciated.
The lower part of the circuit is a simple voltage divider to power the TIP122, which in the original configuration divided the +10V down to +5V. Since I seemed to have accidentally junked the original boards, using the +24V from the existing PSU seems like an easy solution. The ration needed to step down the voltage is 3.8:1 (R37:R23). It seems that a single 3.8K ohm resistor is a little hard to supply, but there are ways around that.
Can someone please confirm or destroy the logic used here before I take the step of ordering the parts?
Thanks!
Mac
