Light Machine Corp. Benchman XTr (retrofit)
9 years 10 months ago #84629 by dynamyte24
steve_a,
That's a nice piece of work!
What are the bearing ID/OD dimensions? I'm trying to get an idea of the size of the part.
Rex
9 years 10 months ago #84630 by TGTROPIC
Tommy,
E Stop appears to be functional as I get indication on the PC when I press or disable the estop button. have not put tested otherwise to verify.
Intelitek did not offer any input as how best to test the encoder circuit. Lots of tiny little wires buried in the machine on 3 seperate axis.
TG
9 years 10 months ago #84632 by steve_a
Thanks Rex, The small bearing hole is .87" diameter and the large bearing is 1.120" diameter. The attempt was to make the interference about .001" I think the bearing was measured and that is the number we got. They are pretty common China (what isn't?) so not sure what kind of precision but it all seems to work. The maximum dimensions are 8.25" by 4.75"
9 years 10 months ago #84634 by steve_a
tommylight, Good thought! The EStop looks like just the EStop switch passing 24V but you are right, if that switch is flaky or bad, nothing will work. I totally forgot about that. TGTROPIC, you should check that. (J34 pins 1 and 2 ... the cable that connects should show a short on those two pins. ) If Intelitek is saying the software is seeing an encoder error, then that would be the encoder_err signal being low. The encoder LEDs are on and that should cause the proper state so encoder_err is high. HDR2 has a jumper and that should be on the left two pins. Pin 1, the left most pin, should have about +24V DC. All the machine can really know is that there is power to all the encoders. It could only know there is a signal error if something moves and nothing can move without power to the Copley Servos.
9 years 9 months ago - 9 years 9 months ago #85051 by MacGalempsy
Azik1 - when I pulled the head off, it was held in place with 4 pins plus the 4 hex socket cap bolts, so there is not much adjustment there. How much is your head off by?
Steve_a - Are you still using the Copley controls and Litton motors for the axes? Also, were you able to access the VFD thru the software? If so, what PID settings were set for the default velocity mode.
Overall, I am having a hellova time trying to get the 4th axis to tune properly. If any of you guys are pros at PID tuning, I would love it if you would remote login to my box hand give me a hand getting it to run properly.
Also, since there are so many people now working on getting LinuxCNC to run their Benchman XT, lets do some group discussion/work on getting these dang ATC working with Classicladder!
Last edit: 9 years 9 months ago by MacGalempsy. Reason: added a few more words.
9 years 9 months ago #85053 by Azik1
Mac, i found only 1 pin and 4 hex bolts to attach spindle, trammed with mallet rotation over Y axis, but still getting 1mil over 3.5inches inaccuracy in rotation over X axis. Looks like shims need to be inserted between spindle and plate, i dont see any other method.
What is do you have for 4th axis ? ATC ? This thing has tons of slop and difficult to tune, although i run it with kflop.
Regards!
Time to create page: 0.338 seconds
