Light Machine Corp. Benchman XTr (retrofit)
9 years 9 months ago #85991 by TGTROPIC
Still no luck..have compressed, zipped and and still unable to upload. first file was JPG so no problem with type and sizes under limits. Problem with Forum? Don't mean to Hijack BTW.
9 years 9 months ago #85995 by tommylight
Just uploaded some pics and a pdf file, some 20 minutes ago, no problems.
Try it from the phone or tablet if you can.
9 years 9 months ago - 9 years 9 months ago #86027 by rodw
TGTROPIC wrote: having trouble uploading the other JPGs for some reason
I use Photobucket for all my forum photos and insert with the IMG command
Photobucket has a link that contains the right format for each photo and you just need to paste into the thread
Last edit: 9 years 9 months ago by rodw.
The following user(s) said Thank You: TGTROPIC
9 years 9 months ago #86032 by dynamyte24
x-Intelitek Engineer wrote: Machines could be configured and built for the fourth axis, but not shipped with the 4th axis due to budget constraints and the 4th axis was purchased at a later time.
Thanx for that info, Don.
I'd like to run my Benchman without the 4th, but I get an Error (4th axis encoder open) IIRC.
I have unchecked "Rotary Axis" in the Benchman Setup panel (pg E-66), but the error persists.
Is there something else I need to do?
Rex
9 years 9 months ago #86054 by x-Intelitek Engineer
Rex,
In order to run a 4th axis ready machine without the 4th axis, there is a jumper plug that must be plugged into the connector on the back wall of the machine. I will have to look-up and find that information for you. I will see if I can find it later today.
Don
