Hitachi Seiki VM-40 Retrofit
12 years 9 months ago - 12 years 9 months ago #42712 by davo727
Nice project. Thanks for posting it. What part of the world are you in?
Last edit: 12 years 9 months ago by davo727.
12 years 9 months ago - 12 years 9 months ago #42713 by bevins
Replied by bevins on topic Hitachi Seiki VM-40 Retrofit
I'm in Montreal, Canada
still learning the ins and outs of LinuxCNC struggling but getting somewhere.
Last edit: 12 years 9 months ago by bevins.
12 years 9 months ago #42800 by bevins
Finished wiring inputs and outputs on the 7i77 .Everything is working so far.
12 years 9 months ago #42817 by BigJohnT
Very neat wiring! You don't see that often.
JT
12 years 9 months ago #42857 by davo727
What are all the boards and modules on the panel?
12 years 9 months ago - 12 years 9 months ago #42862 by bevins
12vdc and 24vdc power supplies, distribution boards with thermo reset fuses and fused terminal blocks and 4, 4 relay boards.
A 7i77 board and getting 7i84 board tomorrow.
I added a 120VAC relay to send dc voltage through it then to The dc distribution boards cause when I shut power off on the power supplies relays on the power supply fired and because dc power was not being discharged from the caps the 7i77 received spikes. So now when I shut ac power dc gets cut off with no spikes.
The following user(s) said Thank You: davo727
Time to create page: 0.314 seconds
