sspeed33317 wrote: The whole moving the Z axis is the main reason I decided to do this.
Now I can do the whole tool change in ladder logic. I am really weak in programming.
That is likely to be a big obstacle.sspeed33317 wrote: And my shop is on the other side of town.
A Boss without a toolchange is pretty easy with LinuxCNC too. That's a stepper system. There is even a config for a Boss system included as a sample config with LinuxCNC. I don't think that Camsoft would necessarily be easier with the Haas than LinuxCNC. (It might be, but the Boss comparison won't tell us that)The learning curve is sort of intimidating. Recently I almost caved in and bought Camsoft
I built a machine with my old boss about 10 years ago and it was a piece of cake with Camsoft.
I have always thought that I should learn ladder, but I have aways found other ways. I didn't know any C at all until I started playing with LinuxCNC. But I had programmed in other languages, to that's not an entirely fair comparison. I had to learn G-code from scratch too. C is a lot easier than G-code.Coding something for a C component is probably out of the question, ladder logic doesnt look
too bad, I am trying to find a good book.
I admit that I have lost track of which machine is which, and it is too late here to read back through the thread, but isn't this a system with a Geneva mechanism and a motor? If the original machine managed to work by running a motor then stopping the motor when the right tool appeared, then so can LinuxCNC. If the original system worked, then LinuxCNC can operate it.Subroutines will work but Id rather not have to modify the way the tool changer works
I think I would have to install a encoder and treat the tool magazine as a axis .
The User Map shows 30 users in FL, but no names I recognise. But don't underestimate how effective the forum can be (and IRC even more so, for real-time chat)I wish someone with experience with LinuxCNC lived close by, would make things so much easier.
