14x40 Lathe Retrofit
  • giz
  • giz's Avatar Topic Author
  • Premium Member
  • Premium Member
03 Dec 2014 04:53 #53614 by giz
14x40 Lathe Retrofit was created by giz
I'm starting this thread to ask for some help and guidance updating the retrofit on my Takisawa 14"x40" tool room lathe. It was previously retrofit with Centroid controls, ball screws, linear scales, and DC servos. That control went up in smoke a couple years ago, which is when I was given the lathe in trade. I did a lot of research and planned out an update but the project fell off the radar for various reasons, but one was my indecision on how to proceed.
I'm now at a point where I want to get the lathe up and running. I want to ditch the linear scales and current motors, but obviously will keep the ballscrews. Everything else will have to be replaced. I also have a red cap Fanuc servo (model 10, serial A06B-0501-B201, 12Nm 2000rpm with Pulse Coder and brake) that I would really like to use as the spindle motor - it would be replacing a 2.2KW DC motor.
I like the Mesa cards and prefer to stick with those over the Pico systems.
I'm eyeing these servos to replace the Z and X axis motors: www.ebay.com/itm/IIS-Industrial-Indexing...&hash=item565677f144. Thoughts? I can't find a lot of info on them but the size and price is right.
My understanding is that from Mesa I would need:
5I25
7I77
8I20 (replaces the servo driver for the big Fanuc, right?)
I would also need smaller servo drivers, but here is where I am a bit confused. Does Mesa have a card that would drive the servos listed above (or any other servo from Yaskawa, Mitsubishi, etc)? Could I use a generic driver from AMC, or do I need matching drivers?
I believe the 5I25 has all the I/O I would currently need (mainly limit switches).
Lastly I really need some help understanding the best way to power these servos.
Any help is appreciated! A few years ago I had a much better understanding of the CNC world and now I'm feeling a little lost. This is my first project and I'm excited to get the machine running after walking past it for 2 years just idle.
03 Dec 2014 08:44 #53627 by andypugh
Replied by andypugh on topic 14x40 Lathe Retrofit
It rather depends on the nature of the encoder that those motors have. If it is a proprietary interface then there might be problems, if it is quadrature then it is very easy. If it is BiSS or one of the other absolute encoder formats supported by Mesa then it might be ok too.
I am running a set of 750W servos very similar to those on my mill using Mesa 8i20 boards. They may be a bit over-specified for the job, but work nicely.
AMC drives should work. It might take some effort to sort out the commutation if those motors you are looking at don't have Hall sensors. (and the connector doesn't look to have enough pins to have both encoders and hall sensors).
I think those motors would be a bit of a gamble without a bit more information about them
Have you tried contacting the URL on the motor plates? I had a look at their web-site but nothing seemed to match those servos. I suspect that they might actually be Panasonic.
As you have some perfectly good DC servos and drives and power supply why not start off using them? The 7i77 will drive them perfectly happily. If they are inadequate in some way, then upgrade then.
  • giz
  • Premium Member
  • Premium Member
03 Dec 2014 14:33 #53633 by giz
Replied by giz on topic 14x40 Lathe Retrofit
Thanks for the response Andy, I was hoping you'd chime in.
I hear you on the uncertainty with those motors. I looked up some servos I was interested in years ago from DMM Tech today and learned that I could pair them with Mesa boards so now I'm leaning that route. The 750W servos with the new Dyn2 drives would fit well on this machine and the Mesa boards would allow me to run the Fanuc servo as the spindle.
The reason I'm avoiding using the DC motors is somewhat of the same objection you had for the ebay motors - I don't know anything about them and could not find any info online. But I also didn't consider the possibility of using the same control boards for both motors...
So it sounds like I could pick up a 5I25, 7I77, some power supplies and maybe get up and moving fairly quickly. I'd have to figure out the pinouts my DC servos and tune them, as well as figure out how the spindle encoder works (its 4 or 5 wires). Am I missing a component here - the servo drivers?
I just checked an all the encoders cables are 6 wire. The servos have 4 more wires, 2 pair of black and red.
The alternative is to go all-in with the DMM motors (self tuning and well-documented) and the Fanuc servo as a spindle. Does you BLDC config work for the Model 10 (not the 10S)? This sounds like it could be the most difficult part of the job, but a live C-axis is important to me down the road. I also have no idea what power supply the Fanuc would need.
I'm starting to remember why I never made any progress on this before! Too many options.. haha
03 Dec 2014 21:08 #53637 by andypugh
The old Dyn2 was a bad choice as it was 0-5V + direction with the rather unpleasant feature that the 0-5V input floated high (max speed) when disconnected. The new DYN2 looks OK in that regard except that it does not appear to offer encoder output to the controller.
If you retained the glass scales and ran the motors in velocity-servo mode then this would probably be OK. Or you could run the servos as steppers (though not with the 7i77, you would want 7i76)
There isn't much to know about DC servos. You apply volts, they go round :-)
I would expect two big red and black cables to be servo power and two thinner ones to be the output from a Tachometer.
The original Centroid control used velocity-mode servo drives, where the drive output is (approximately) the command voltage in - the tachometer voltage output. The Centroid controller then sent velocity commands to the drives to achieve the required position on the scales. (Or that is my understanding from what I have read here).
So, I am a little unsure which encoders you mean?
To run the servos + tachs you need an old-school serve drive, but the machine probably has perfectly good ones, and the right power supply.
I don't know. Do you know what the encoder output is? If it is 4-wire Halls then that is handled.
  • giz
  • Premium Member
  • Premium Member
04 Dec 2014 00:36 #53642 by giz
The DMM motors can take step/dir or +/-10v, but the loop is closed at the drive. Does the 7I77 require that I connect the encoders and close the loop in the control? Am I losing anything by using the 7I76 and step/dir in terms of performance?
Ahhh, you are jogging my memory here. I remember now thinking these were run in velocity mode with the tachometer and that was a big reason I planned on moving away from them. I only have the Z scale (and the "reader" is disassembled, unknown if I can fix it) and I don't have anything from the original control box (servo drives, power supplies, etc).
Sorry about the confusion on the encoders, clearly I'm still a little confused myself! But I believe the DC motors are fitted with resolvers and that is what the 6 wire cable is for. Since it's the same cable, I think the spindle may have a resolver as well.
I don't know what the encoder output is. I can pop the top off tonight and see if I can get more information on the encoder. I do know its labeled as a Pulse Coder.
04 Dec 2014 01:44 #53650 by andypugh
Ah, well, in that case the 5i25/7i77 can't be used with the existing motor feedback.
It is moderately easy to check if the feedback device really is a resolver, a mulitmeter will show a few K resistance between three separate and isolated pairs. (the primary winding might be a different resistance, at least two should be identical).
I have rather a fondness for Resolvers, but if you want to use them you need a different style of Mesa card and the 7i49. I am using a 5i23 and 7i49 on my milling machine. (which has resolvers). There is a cheaper option now of the 5i24 and 7i49. There might be a DB25 version of the 7i49 in the works, but no real reason to wait for it.
The 14 pin Pulsecoders are compatible with bldc. You may be able to work out what you have from here:
www.cnczone.com/forums/servo-motors-driv...uc-pulse-coders.html
However, all is not lost if you have a different one, there is firmware to put Fanuc absolute encoders on some pins of the FPGA card. In fact in some ways the 4 x Hall + quadrature combination would be a nuisance with Resolvers on other motors.
If you have a way to mount the Fanuc motor to the existing spindle + Resolver then you could ignore the motor encoder, and just use the motor Hall sensors.
  • giz
  • Premium Member
  • Premium Member
04 Dec 2014 02:50 #53652 by giz
Knowing what I know about the dc motors and their resolvers, I think I'll stick to the plan to update the X and Z motors. And for the DMM Tech, it sounds like I need to go with the 7I76 because the loop is closed at the drive.
The spindle resolver is setup in a way that would easily allow me to swap the DC inudction motor for the Fanuc servo and keep the resolver. My Fanuc servo has a 17 pin encoder and I'm certain it is from the same family as the one jmelson talks about here: www.cnc-arena.com/en/forum/fanuc-abs-pulse-coder--172614.html
It looks like he figured it out but I don't want to throw hardware at a problem if I don't need to, plus still I want to stick with Mesa cards. I could replace this servo with another if needed - I have to weigh my options. The current resolver will need an additional Mesa card, the current Fanuc servo might need Pico hardware, etc.
04 Dec 2014 03:12 #53654 by andypugh
The drives can run either with the loop closed at the drive, or closed elsewhere. One option might be to add encoders on the screws, or use the existing resolvers on the screws. (or fit some cheap glass scales).
If you use the Dyn3 drives from DMM then those have encoder output for LinuxCNC to use, and are a rather better fit for the LinuxCNC philosophy of motion control in the PC. However those drives are rather more expensive.
It is not inconceivable that a Mesa card could read the DMM absolute encoder. It would depend on the data format used, but if it is BiSS or SSI then firmware modules exist.
Mesa cards can read Fanuc with the right firmware: www.linuxcnc.org/docs/html/man/man9/host...html#Fanuc%20encoder.
  • giz
  • Premium Member
  • Premium Member
05 Dec 2014 08:35 - 05 Dec 2014 08:39 #53700 by giz
They have a data sheet available for the old 14 bit encoders - it says they use SPI. It looks to me, from just reading the website, that the Mesa 5I25 can handle that. I'd have to contact DMM about the new encoders but if they are the same it seems like I could potentially bypass the drives, but I'm still not certain the benefit of closing the loop in the control vs. the drives.
I'm still weighing my options but the DMM motors/drives look to be a sure thing. There is still lsome uncertainty about the Fanuc motor on my part, and I'm starting to wonder if I would be better off trying to find another ~2kW motor ebay.
Last edit: 05 Dec 2014 08:39 by giz.
06 Dec 2014 02:04 #53730 by andypugh
If it is just the motor that you are trying to drive and you don't have the Fanuc motor driver, then it ought to be moderately straightforward. There is only one way to drive a 3-phase brushless motor. The only puzzle is the encoder/commutation format.
Time to create page: 0.096 seconds
