Crusader II retrofit
10 years 8 months ago - 10 years 8 months ago #69547 by jamby
Replied by jamby on topic Crusader II retrofit
Went back to it, powered up all 3 axis motors are getting power. When using the jog button the on screen display shows the axis moving but the machine doesn't. If the jog is large enough the "joint 0 following error" appears. I'll go back and recheck the wiring and try again.
And the pid settings.
Jim
File Name: Alliant_02-2-3.ini
File Size:3.14 KB
File Name: Alliant_02-2-3.hal
File Size:9.94 KB
current files
Last edit: 10 years 8 months ago by jamby. Reason: added current files
10 years 8 months ago #69548 by PCW
Replied by PCW on topic Crusader II retrofit
Sounds like the analog out is not connected properly
( so the drives are just holding due to being in velocity mode with a velocity of 0 )
Are the drives disabled when you get a following error?
if not, fix this before proceeding
10 years 8 months ago #69549 by jamby
YES as soon as the error comes up the drives are killed. Also linuxcnc power on button comes out.
Which ones the analog out??
Jim
10 years 8 months ago #69554 by PCW
7I77 TB5 pins 4,8,12,16,20,24
AOUT0 through AOUT5
(you will only be using 0..2 and perhaps 5 if you have a analog spindle control)
10 years 8 months ago #69556 by punking
Replied by punking on topic Crusader II retrofit
No eBay APP ID and/or Cert ID defined in Kunena configuration@PCW
These are the resistors that Jim used on the amps:
Please advise if these are correct.
I looked at them and they spec. Out at 1000 ohms but I'm not certain of the other specs. Maybe these are killing the signals at the amps.
10 years 8 months ago #69559 by PCW
Where were these resistors connected?
Time to create page: 0.324 seconds
