Crusader II retrofit
10 years 8 months ago #69660 by punking
Replied by punking on topic Crusader II retrofit
My system does the same dithering . But, it holds position between tool changes and holds origin from one setup to the next. So in all it hasn't been a problem.
10 years 8 months ago #69665 by jamby
Replied by jamby on topic Crusader II retrofit
Tried it with all 3 axis wire in.
X slow drift in positive direction maybe a 1 in 10 min.
Y runaway in positive direction hits .5 ferror drifts to a halt. I think.
Z holding steady with slight dither.
X Z tested with Y disconnected.
Don't know where to go now. I've traced the wiring and don't see a problem but I may need to pull it apart and test each lead.
Jim
10 years 8 months ago #69667 by jamby
Yes it spits out a
joint 1 following error
10 years 8 months ago #69668 by PCW
Replied by PCW on topic Crusader II retrofit
Sounds like X analog out is not connected (or P term is 0)
Likely means you need to reverse the analog out sign on Y
( Remember my list of 4 things needed to get the servo system working )
10 years 8 months ago #69670 by jamby
PCW
Ummm hate to admit it but X analog out and P term are subjects I am more then a bit foggy about. Are you referring to the ENA0 and COM at TB5 DRV0?
P term is that the P value in the ini file?
Thanks for your help
Jim
10 years 8 months ago #69671 by punking
Since you are running linuxCNC
Go up to tool bar and select machine>calibration
You'll se tune 0
Tune 1
Tune2
These are you axis'
These machines are running a pid (velocity) loop nested in a pid loop ( at least that the way I see it)
LinuxCNC allows us to fine tune the servos
P value on mine happen to be 45
I is 0
D is 0
Bias is 0
FF0 is 0
FF1 is 0.1
FF2 is 0
Try on all axis and see how it reacts
The following user(s) said Thank You: jamby
Time to create page: 0.242 seconds
