Crusader II retrofit
10 years 8 months ago - 10 years 8 months ago #69539 by punking
Replied by punking on topic Crusader II retrofit
also, i just looked at your ini file above . you may want to change your setting a little for each axis:
MIN_LIMIT = -0.001
MAX_LIMIT = 8.0
to
MIN_LIMIT = -10
MAX_LIMIT = 10
you may limit out before anything happens.
Last edit: 10 years 8 months ago by punking.
10 years 8 months ago #69541 by jamby
Replied by jamby on topic Crusader II retrofit
Just went back to the shop and checked the wiring on the westamps.,.., it was wrong. Now with the main control powered up, when I push the linuxcnc power on button the drive motors start to growl and the hand wheels can not be turned.
How ever it still doesn't respond to input thru the jog button on X or Y axis....ummmm
Jim
10 years 8 months ago #69542 by punking
how about z axis?
10 years 8 months ago #69543 by punking
also, does it still kick out a "joint 0 following error" error?
10 years 8 months ago #69544 by jamby
With the changes to the ini and hal files suggested by you and PCW it now has no joint errors and when linuxcnc is turned on the motors engage. I have left Z axis alone for now as those crashes come quick
Jim
10 years 8 months ago #69545 by punking
At this point , I would choose an axis and carefully trace your wiring between the amp and the 7i77. Make certain that portion is wired correctly.
The fact that the drives enable and lock you servos in my opinion is a good indicator that it is setup correctly. It must be a setting in linuxCNC that is holding things up.
Maybe set pid settings and ff settings all to zero. Only do this on maybe X axis first.
Time to create page: 0.099 seconds
