Fanuc Servos on LinuxCNC
- jonesturf
06 Feb 2016 04:15 #69690
by jonesturf
Fanuc Servos on LinuxCNC was created by jonesturf
I'm thinking about retrofitting a Haridnge CNC lathe over the LCNC if I can't get the Fanuc OT-B system working. Wondering if anyone knows if there are ways to control the servos using the Fanuc drives. The axis servos are Fanuc 10S (can grab numbers tomorrow) and the spindle is a Fanuc 6S A06B-0754-b270#3000.
I assuming you can run the spindle off a VFD but what about the encoder?
The following user(s) said Thank You: mblaszkiewicz
- jonesturf
06 Feb 2016 14:24 #69698
by jonesturf
Replied by jonesturf on topic Fanuc Servos on LinuxCNC
I see that Pico has 2 Fanuc encoder converters. Would these work with my motors? FYI they are all red cap Fanucs.
- jonesturf
06 Feb 2016 20:04 #69708
by jonesturf
The axis servos are fanuc a06b-0315-b003#7000.
I sent Jon at Pico an email regarding compatibility with his boards.
- emcPT
- Thank you received: 95
07 Feb 2016 16:27 #69736
by emcPT
Replied by emcPT on topic Fanuc Servos on LinuxCNC
If you cannot use the built in encoders (recommended) you should be able to replace them with standard quadrature encoders and use a readily available servo drive. I have done that in the past.
Still, using the original servo/encoder/drive would be the best way.
- jonesturf
08 Feb 2016 01:29 #69758
by jonesturf
Fanuc Servo Amplifier, A06B-6058-H334, A16B-1100-0330/03A for the axes
Fanuc 6S A06B-0315-b003#7000 motors on the axes
Not sure if that helps anyone but thats what I have.
08 Feb 2016 19:17 #69777
Replied by andypugh on topic Fanuc Servos on LinuxCNC
There is a module for the Mesa cards that works with some models of Fanuc encoders (the serially-communicating absolute ones).
linuxcnc.org/docs/2.7/html/man/man9/hostmot2.9.html#BiSS
- jonesturf
08 Feb 2016 23:17 #69795
by jonesturf
I cleaned the gunk off the motor and low and behold it is a pulse encoder. On the x at least. I would hope z would be the same.
- jonesturf
08 Feb 2016 23:20 #69797
by jonesturf
It appears to be an aa64 encoder like that which is described in the link you sent me. What Mesa card is that Andy?
09 Feb 2016 00:26 #69801
The Module can be included in the firmware for any of the FPGA cards as far as I know. I am not sure if it appears on any standard firmwares.
- JR1050
- Thank you received: 31
09 Feb 2016 22:51 #69888
by JR1050
Replied by JR1050 on topic Fanuc Servos on LinuxCNC
The Fanuc spindle motor is a permanent magnent motor. You will need a vfd that can control a pm motor. They are not easy to tune. I have a Hitachi wj series controlling a 6s motor on a mill. Last I checked there is no encoder feed back to the drive available. Yaskaw a, Fuji and mistsubishi also make drives that will control a pm motor. They might by now have incorporated feed back. It's not necessary.
Time to create page: 0.426 seconds
