Fanuc Servos on LinuxCNC
- jmelson
- Thank you received: 126
21 Feb 2016 17:53 #70449
by jmelson
Replied by jmelson on topic Fanuc Servos on LinuxCNC
Sorry about the late reply.
A06B-0315-b003#7000 has the 3000P encoder with 17-pin round connector. This gives 12,000 counts/rev, differential quadrature with index. This part is totally standard. The commutation data is the Fanuc proprietary code on 4 wires, which our Fanuc Encoder Converter converts to standard "Hall" signals. The motor is actually a 10S
(there is no model 6S) which is a pretty big motor. It is rated at 7.6 A stall, so the peak is about 50 A. My PWM servo amps can deliver 20 A peak. There are some AMC servo amps that can take in digital PWM signals.
The Pico Systems universal PWM controller could be used with this.
Jon
Jon
- jonesturf
21 Feb 2016 19:08 #70453
by jonesturf
Replied by jonesturf on topic Fanuc Servos on LinuxCNC
Thanks. I'm still trying to get power to the machine to see if the original control is fixable or not. You're correct it is a 10S on the axes. The 6S was the spindle servo.
Time to create page: 0.092 seconds
