Do you really need a spring loaded pinion drive?
05 Sep 2016 07:36 #80042 by emcPT
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Sep 2016 11:01 #80048 by rodw
If you need motivation:
forum.linuxcnc.org/forum/show-your-stuff...m-powermax-125#80041
Very nice. My foray into CNC plasma comes from a zero base but I've moved from a ghetto home build to something of commercial quality (I hope). Eventually I think servo motors are on the horizon once I get a working system.
I'd really be interested any data on air flow for down draft plasma tables if some one can help.
05 Sep 2016 13:17 #80053 by cncbasher
Replied by cncbasher on topic Do you really need a spring loaded pinion drive?
i use 3 low voltage 8" fans below the grid , into the end of the pan , this is enclosed to funnel down to one 6" flexiable pipe
which is then vented out , the fans work fine by drawing the dust down and out . they are not running fast , but enough to cause a negative flow out , i built it more for air mass movement than speed .
07 Sep 2016 19:45 #80161 by andypugh
Surely grids get cut too? Why not float the workpiece on a pool of mercury?
I admit there are a few possible minor drawbacks, but I am sure that dealing with those isa mere detail.
  • rodw
  • Platinum Member
  • Platinum Member
18 Sep 2016 12:19 - 18 Sep 2016 12:20 #80559 by rodw
Its taken a while to find some time to get back onto this project but today, I got this far
There are some pretty tight clearances to get the stepper and bearing aligned along the shaft perfectly and I surprised myself. Everything turned out perfectly aligned with no binding at all. (After I noticed the centre bored hole for the stepper was out of position by 3mm on my first drawing).
Last edit: 18 Sep 2016 12:20 by rodw.
18 Sep 2016 13:19 #80562 by tommylight
Replied by tommylight on topic Do you really need a spring loaded pinion drive?
Two problems with that setup:
The pinion is to big so you will have around 10cm of movement for one revolution of the motor
To much vibration at low speeds
Resulting in jerky movement and the end result.
Lowering the current to the motor will mitigate both problems to a certain extent, at the cost of speed and acceleration.
From experience, you need about 1-2.5cm of movement per motor turn, so use of reduction is necessary.
Move the motor to the side and slap 2 pulleys at 1:3 to 1:5 ratio, that will do nicely.
Do try it as is, later you do improvements.
18 Sep 2016 13:57 #80567 by emcPT
Take tommylight information for serious. You will not have a good movement with that.
I might guess that a 1/5 to 1/10 reducer is suitable for your setup.
  • rodw
  • Platinum Member
  • Platinum Member
18 Sep 2016 20:59 #80583 by rodw
Thanks guys. I wondered about that. I will take it all on board but may wait until I get a working system so I can experiment.
The pinion is a 20 tooth 1.5 module gear so it is 30mm per revolution. Somewhere I had read that 25mm per revolution was the sweet spot and 30mm was as close as I could get to that when I went looking for a rack and pinion. Maybe a 2:1 reduction is where I should be looking then? That would give me 15mm per revolution.
Finally, what module gear rack is the best choice? I have not bought the X axis racks yet.
  • rodw
  • Platinum Member
  • Platinum Member
18 Sep 2016 21:06 #80584 by rodw
Ooops, I had never actually measured the travel, you guys made me go and do it. I was way wrong, Tommy was right! It measures out at about 90mm travel! Back to the drawing board!
18 Sep 2016 21:09 #80585 by andypugh
20 x 1.5 x pi per rev, I think.
You might as well build it and make it work anyway, seeing stuff actually move is a real encouragement.
Time to create page: 0.152 seconds
