frecel wrote: I've been reading a lot on controllers trying to educate myself more on the subject what I can't figure out is how to hook up the the actual plasma power source to it.
The plasma we are thinking of getting has contacts that are normally open and close when the torch switches from the pilot arc to cutting arc.
I'm not sure how to make sure I'm selecting the right controller to take advantage of that.
If its like my as yet unhooked up plasma cutter, the machine torch simply requires a switch to replace the switch on the hand torch.. On my Mesa hardware, I have yet to wire this in but I have a 24 volt relay to replace the switch. The relay coil will be wired to a 7i76e Output pin on one side and earth on the other. Then the wires to the plasma cutter go to the other side of the relay. I have not followed it right though yet, but I think the output to use is configured is Spindle on. This will light up the output which triggers the relay.
For Arc OK, my instructions say this is a dry mechanical contact at the plasma end (eg. a relay). So run 24 volt power to one side of the ArcOk switch and the other side to a 7i76 input. I think this is configured as the Spindle at speed signal.
I have seen an external THC that ran 24 volt internally but the logic levels on a parallel port breakout board were 5 volts. In this case, they used a 24 V relay to switch constant 5 volt to a BOB input.
