Brother TC-225 / TC-229 adventure!
9 years 2 months ago #96915 by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
well, its on its way - I ordered 4. now I can twiddle my thumbs for a few days.
actually, I guess I can try to read some of the inputs and see where they end up..
9 years 2 months ago - 9 years 2 months ago #96920 by andypugh
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
ihavenofish wrote: haha, $20 shipping. sigh
I have a tube of them, but that's no help for you.
You could have tried Amazon or eBay:
www.amazon.com/dp/B00CL7X2IM/
Last edit: 9 years 2 months ago by andypugh.
9 years 2 months ago #96921 by ihavenofish
it was $8 in the end as i went to digikey. i prefer them and mouser because the parts arrive in 24-48 hours, as opposed to weeks usually from ebay/amazon etc.
so all good i think.
9 years 2 months ago #96977 by ihavenofish
transistors delivered, have to wait til tonight to try em :/
9 years 2 months ago #97018 by ihavenofish
transistors installed into cable and.... click-clock, works. :) drives are powered by the machine on button in linuxcnc.
on to the drives. it turns out that the wiring drawing for the drives was....
correct! :) x axis running. I did some tuning according to a guide I found on this forum, and its pretty decent actually. I set it to 787 ipm max speed (original speed) and 0.5G acceleration and it tracks kinda ok. I have some questions to see if I can make it better.
first, I am assuming the "1m" scope setting means 0.001 units, which is 0.001" on this machine.
if that's correct, then at all speeds my axis tracks within about 1-1.2 divisions. most of the following error is of course during acceleration. travel is very smooth at most speeds, its a little bumpy "sounding" at the lower end of things (1-2ipm), but following error isn't very big. at constant speed, it tracks very close to 0.
my pid settings turns out to be
P = 125
FF1 = 0.675
FF2 = 0.001
dead band = 0.00001
everything else is 0.
my encoders are 4096 count (1024 line), 5 pitch screws, 4000rpm.
so what would the suggestion be to tighten this up? or is it pretty good as it is?
I also should not, I think 0.5G might be higher than it was stock, OR, linuxcnc's lack of jerk control is making it feel way more aggressive. at low speeds you get a bump start to each move as its basically instant acceleration, whereas the original control seems much smoother.
thanks for all the help so far! :)
9 years 2 months ago #97026 by andypugh
You should be able to pull the steady-state error down with a bit of I gain. Your results sound rather good for a P-only control.
Time to create page: 2.606 seconds
