Brother TC-225 / TC-229 adventure!
8 years 11 months ago #102477 by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
well that works :)
thanks!
you don't happen to have a hal scope pic while its doing that?
your f error is high - is that error during acceleration, or through the whole move? mine is about 0.025mm +- spike during acceleration, then only about 0.005mm or so during the steady motion.
only other thing I notice is you have deadband at 0. I cant remember what happened when I tried 0, or if I tried 0 at all.
also what drives and motors and encoder counts are on that machine?
8 years 11 months ago #102482 by PCW
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
Depending on your Gcode you may always have to have G64 PN QM in force to do smooth motion.
Are these set to reasonable values?
Also its easy to differentiate between tuning and jerk limiting issues with LinuxCNC by doing a motion that is inherently jerk limited (like a G2/G3 helical move) Once up to speed, commanded motion will be jerk limited
8 years 11 months ago #102483 by ihavenofish
g64 p0.001" q0 is standard for me. this behaves smooth.
circles also tend to be smooth, but have a bit too much error for my tastes (to be fair, you don't generally make a finish pass at 200+ipm and the error is only .001" - ive seen worse in better machines.
the error is actually not my complaint. if it tracked at 0.0005" at speed under 50ipm and .001" at speeds up to 200ipm and strayed a bit at 787 which is primarily only rapids, it would be perfectly fine. its the clunk at the beginning of each move which in the case of the z becomes instability that makes the think not usable yet. x is borderline, y is a bit bad, z I don't even like jogging in tests its so bad.
we also have the trajectory planner misbehaving as mentioned before, though that's got nothing to do with the straight line tuning.
I have the files up there, please look to see if anything is clearly not right.
8 years 11 months ago - 8 years 11 months ago #102484 by ihavenofish
laserK wrote: Which brings me to the next problem: I don't have a manual for the Toshiba RA Drive.
There are 6 potentiometers on the front. I, SZ, P, SPD and WZ, UZ
I and P are clear,
SPD = speed?
SZ = ?
WZ = ?
UZ = ?
spd don't touch, that's the v/rpm reference.
sz/wz/uz, no idea, theres nothing on my drives that have a similar label. on mine you have 2 gain pots, which represent p and I though not labeled p and I - they have a diagram showing what they do.
@ihavenofish
Do you know the stock values of the acceleration? Were does this information of jerk limit in the brother control come from? Could the jerk control be an analog low pass filter?.
youd need to run the stock control to read them. I suspect yours is slower than mine a little. mine is 150ms. what that means is 150ms from 0 to 787ipm (591 on z). that works out to roughly 0.225g on the x and y or 87in/in2 as many people are used to. ive tried every acceleration from 10in/in2 to 200in/in2 (0.5g) and there is ALWAYS the same clunk. less pronounced when its slow, but not much.
as super low speeds (say, 2ipm) you don't notice the clunk, because the acceleration to that speed is basically instant. it comes into play mostly above 10ipm or so.
Last edit: 8 years 11 months ago by ihavenofish.
8 years 11 months ago #102499 by laserK
Replied by laserK on topic Brother TC-225 / TC-229 adventure!
Thanks! I'll try P and I then. My guess is, that SZ, WZ, and UZ are limits for Speed, Power/Current, and Voltage?
I'll also check the velocity ramps of the original control to get a feeling for the max acceleration.
8 years 11 months ago #102500 by ihavenofish
i just thought of something. alot of amps have jerk control built into them as a filter - usually modern step controlled ones.
but... if this drive has a filter, would it cause linuxcnc to attempt to compensate during acceleration and deceleration and basically have the 2 fighting?
that's just a random thought here.
the only other thing that might be different on the brother control i that it may be quite lazy on following as its primary use is point to point. so maybe it has a broad allowance when doing curves. hmm.
Time to create page: 1.006 seconds
