Brother TC-225 / TC-229 adventure!
- laserK
8 years 10 months ago #102632
by laserK
Replied by laserK on topic Brother TC-225 / TC-229 adventure!
I did some tuning on the servo amps. The value for P was at the lowest possible setting. Increasing it was a huge step forward. I am not done with the tuning, but so far I could reduce the maximum ferror to ~0.03mm @ 0.1G and 10m/min. I will try larger values of P and I on the servo amp soon. Right now I need a lot of FF1.
- Thank you received: 5334
8 years 10 months ago #102639
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
For FF1 its not so much "a lot" but rather the right amount.
(If you scale the analog out in machine units per second instead of volts, FF1 should be 1.000)
- laserK
8 years 10 months ago #102640
by laserK
right now ff1 is around 3 with dimensionless scaling as you suggested. That seems too much..
~4000rpm @10V, 5mm ballscrew => 33mm/(sV)
8 years 10 months ago #102644
is ff1 3 with maxscale =333? (333 should be mm/S fullscale with you numbers)
- ihavenofish
- Thank you received: 286
8 years 10 months ago #102645
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
if I don't play with D, I usually end up near 0.7ish for FF1
- laserK
8 years 10 months ago #102681
by laserK
I had around 0.1 with maxscale = 10. that should translate into ~3.3 with maxscale 333, right?PCW wrote: is ff1 3 with maxscale =333? (333 should be mm/S fullscale with you numbers)
Time to create page: 2.129 seconds
