So, I have to move, and I think one of the 2 brothers I have in storage should find a new home.
My thought is to keep the tc229, and take the spindle motor and drive from the tc225 and put it on the tc 229.
so the tc 225 would go for sale as a retrofit project with no drives, no motors, no control panel or main board, but everything else youd actually need for an easy linuxcnc conversion in tact.
as is specs would be:
- good linear guides with good seals
- good ball screws with 0.0004 to 0.0008" backlash. repacking would get them perfect again for minimal cost.
- good way covers and seals.
- easy to interface relay and io board with all the contactors, power supplies and transformers and braking resistors
outer cabinet has been acid cleaned and ready for new paint
- atc carousel is in perfect condition, no broken arms, I have linuxcnc code to control it in a reliable bi-directional; fashion (however you need to work out the save zone travel limits)
If anyone would like this as a jumping off point, I'd like to get rid of it soon - before march. if I end up having to move it, ill just keep it
