Brother TC-225 / TC-229 adventure!
6 years 7 months ago #160085 by HalaszAttila
Hello,
can you explain a little bit more detailed how i can add together the Z and W axis? Because i work on the same machine, i i want to solve tool changer mechanism to be safety.
I try to configure Z axis 250mm work length and above them W axis.
W axis MAX 140,0
W axis MIN 0,0
Z axis MAX 0,0
Z axis MIN -250,0
with mux2 and, tristate components a combined the commanded signals form Z and W axis motion + encoder feedback signal with one PID module, that controlled the servo driver.
But because of floating point modules (mux2, tristate) in the commanded and feedback signals has 1-2 PLC cycle delay, and this is totally upset the PID control.
With just Z axis, following error is about 0,005 mm, with W axis and float modules, on the same speed it is about 0,2mm.
What you think how can i solve the ATC with Z + W axes, when W is the restricted area of tool changer.
Thanks.
6 years 7 months ago #160092 by tommylight
Deleted double post.
P.S.
@HalaszAttila
There was a user here a while back trying to retrofit a punch press, similar to the one you did some years ago, but we could not find any info on how you did it or any configs, that would help him.
6 years 7 months ago - 6 years 7 months ago #160141 by HalaszAttila
Sorry, I dont find here in forum any topic about punch press retrofit.
Last edit: 6 years 7 months ago by HalaszAttila.
6 years 7 months ago #160551 by andypugh
I think that the answer might be to do the calculations in the kinematics module (ie use a slightly modified trivkins)
6 years 7 months ago #161571 by rmu
I acquired a TC225 about a year ago and am in the process of converting it. As i have no manuals and figuring out pinouts is a very tedious process I wanted to ask if you could share the pinouts of the connectors to the spindle and servo amplifiers? Thanks.
6 years 7 months ago #162223 by stal
please tell me if you keep the original spindle motor ? and how you drive this ?
all I know about thi is read on the old manual :
rated output (w) ...3100
rated torque (1lbs.inch) ...104
rated speed (rpm) ...3000
rated voltage (v) ...140
rated curent (a) ....36
maxim speed (rpm) ...6000
thank you!!!
Time to create page: 0.230 seconds
