HURCO BMC-20P retrofit
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
19 Sep 2019 07:45 #145560 by tommylight
Replied by tommylight on topic HURCO BMC-20P retrofit
I did post them on another thread, thought i did post them here but noticed yesterday i did not, so i will upload them later in the evening.
19 Sep 2019 07:47 #145561 by DaOne
Replied by DaOne on topic HURCO BMC-20P retrofit
Thank you. I am sure this will be a big help. Did you ever get your spindle drive figured out or did you replace it?
  • Moderator
  • Moderator
19 Sep 2019 08:08 #145564 by tommylight
I had fixed it, it had some input voltage sensing issue.
I did change all the drives to Granite Devices Argon.
19 Sep 2019 15:08 #145591 by DaOne
Did you keep the Yaskawa servos? I was told by many that none of the drives would work with these servos. I was gonna replace them with Dyn4 servos and drives. Maybe this would be a better way since the Yaskawa servos use a tapered shaft and the Dyn4 are straight. Means I have to make a coupler.
  • Moderator
  • Moderator
20 Sep 2019 10:56 #145655 by tommylight
Here is one of the configs i was using while making the toolchanger work.
The following user(s) said Thank You: evengravy, Jake, giz
23 Sep 2019 03:49 #145906 by DaOne
Thank you tommylight! Really curious if you were able to reuse the Yaskawa servos with the Granite Devices Argon drives?
  • Moderator
  • Moderator
23 Sep 2019 06:46 #145916 by tommylight
No you can not use them as they have proprietary encoders, so changing the encoders was a pita!
23 Sep 2019 06:58 #145922 by pl7i92
Replied by pl7i92 on topic HURCO BMC-20P retrofit
did you change to the Standard 500ppr or did you upgrade to the 2000ppr as for a mesa this woudt be a good replacement
  • Moderator
  • Moderator
23 Sep 2019 07:00 #145923 by tommylight
Dude, the original was 8192 ppr, replaced by 2500ppr to have 10000 counts .
23 Sep 2019 07:04 #145925 by pl7i92
this is a good value what speed can you go on the Mesa Hardware i guess its a 7i77
Time to create page: 0.168 seconds
