Retrofit Matsuura MC-500v
15 Jun 2018 16:02 #112414 by kt600v
Retrofit Matsuura MC-500v was created by kt600v
Hello, dear forumers
I am going to retrofit a (new to me) 1980s matsuura MC-500v (picture attached) whose control system is broken (yasnaq 3000g).
Axis servo drives and xyz servomotors are ok, however spindle controller is broken.
This time I am going to use mesa cards 7i92M + 7i77 which I have no previous experience with. I have done a retrofit before using steppers (Optimum BF20 vario) and pc parallel port which seems to be a lot simpler than this retrofit. This time I'm working on closed loop servos , tool changer, spindle control, coolant pump, etc.
I know, there have been similar retrofits before in this forum.
Right now I'm gathering all the information related. And every advice from you guys would be very valuable to me.
19 Jun 2018 15:52 #112583 by andypugh
Replied by andypugh on topic Retrofit Matsuura MC-500v
It should be fairly straightforward, though there are a number of steps to complete.
It looks like PnCConf knows about the 7i92 / 7i77 combination so that should get you started at least.
To use an ethernet card I think you need a "uspace" version of LinuxCNC. The simplest way to get that is to use the .iso here:
www.linuxcnc.org/testing-stretch-rtpreempt/
(I think enough people have run this that we can downplay the warnings on that page)
The following user(s) said Thank You: kt600v
23 Jun 2018 18:09 #112797 by kt600v
Replied by kt600v on topic Retrofit Matsuura MC-500v
Many thanks andypugh,
I just ordered the mesa cards a few days ago, i think i should have to wait 3 weeks at leasts.
  • Moderator
  • Moderator
23 Jun 2018 20:37 #112803 by tommylight
Replied by tommylight on topic Retrofit Matsuura MC-500v
Using version 09 for quite some time now, i have not noticed any bugs or issues with it, on 2 machines, 1 works every day at least 4 hours the other about 2 to 3 hours every 3 to 5 days.
03 Aug 2018 04:10 #115483 by kt600v
Cards arrived a week ago, as of today, I flashed the bit file 7i92_7i77x2D.bit then I've created a very quick configuration using pncconf (for testing purposes coz there are many parameters I'm not sure about) ,edited and replaced any hm2_pci for hm2_eth,
and 5i25 for 7i92 in the hal file, also in the ini file.
when launching linucnc using my configuration I get the error attached .
I'm not sure what i missed so far.... I'm stuck
03 Aug 2018 09:03 #115495 by andypugh
We need more than that.
Can you press the "select all" button in that error report box, then Ctl-C to copy it all to the clipboard, then paste it in to a message here?
The important information is likely to be off the bottom of the dialog box.
03 Aug 2018 15:54 - 03 Aug 2018 16:00 #115529 by kt600v
I have attached the error log , hal and ini file....
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
Machine configuration directory is '/home/jose/linuxcnc/configs/machine2'
Machine configuration file is 'machine2.ini'
INIFILE=/home/jose/linuxcnc/configs/machine2/machine2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./machine2.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
Running HAL shutdown script
Killing task linuxcncsvr, PID=4534
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./machine2.hal:9: parameter or pin 'hm2_7i92.0.watchdog.timeout_ns' not found
4534
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] microcode: microcode updated early to revision 0x1c, date = 2015-02-26
[    0.000000] Linux version 4.9.0-5-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP PREEMPT RT Debian 4.9.65-3+deb9u2 (2018-01-04)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-5-rt-amd64 root=/dev/sdb1 ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] x86/fpu: Using 'eager' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040005000-0x00000000d8e6bfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d8e6c000-0x00000000d95cefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d95cf000-0x00000000d95cffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000d95d0000-0x00000000d96f2fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000d96f3000-0x00000000da29efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000da29f000-0x00000000da29ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da2a0000-0x00000000da2e2fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000da2e3000-0x00000000dac7ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dac80000-0x00000000dafdbfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dafdc000-0x00000000daffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021f5fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. To be filled by O.E.M./H77N-WIFI, BIOS F4 07/31/2013
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x21f600 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask E00000000 write-back
[    0.000000]   1 base 200000000 mask FE0000000 write-back
[    0.000000]   2 base 0E0000000 mask FE0000000 uncachable
[    0.000000]   3 base 0DC000000 mask FFC000000 uncachable
[    0.000000]   4 base 0DB800000 mask FFF800000 uncachable
[    0.000000]   5 base 21F800000 mask FFF800000 uncachable
[    0.000000]   6 base 21F600000 mask FFFE00000 uncachable
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: update [mem 0xdb800000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xdb000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd760-0x000fd76f] mapped at [ffff9777400fd760]
[    0.000000] Base memory trampoline at [ffff977740097000] 97000 size 24576
[    0.000000] BRK [0x1b4bbd000, 0x1b4bbdfff] PGTABLE
[    0.000000] BRK [0x1b4bbe000, 0x1b4bbefff] PGTABLE
[    0.000000] BRK [0x1b4bbf000, 0x1b4bbffff] PGTABLE
[    0.000000] BRK [0x1b4bc0000, 0x1b4bc0fff] PGTABLE
[    0.000000] BRK [0x1b4bc1000, 0x1b4bc1fff] PGTABLE
[    0.000000] BRK [0x1b4bc2000, 0x1b4bc2fff] PGTABLE
[    0.000000] BRK [0x1b4bc3000, 0x1b4bc3fff] PGTABLE
[    0.000000] BRK [0x1b4bc4000, 0x1b4bc4fff] PGTABLE
[    0.000000] BRK [0x1b4bc5000, 0x1b4bc5fff] PGTABLE
[    0.000000] BRK [0x1b4bc6000, 0x1b4bc6fff] PGTABLE
[    0.000000] BRK [0x1b4bc7000, 0x1b4bc7fff] PGTABLE
[    0.000000] BRK [0x1b4bc8000, 0x1b4bc8fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x3525b000-0x36924fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000D96D6070 00005C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000D96DF4A0 0000F4 (v04 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000D96D6160 00933B (v02 ALASKA A M I    00000012 INTL 20051117)
[    0.000000] ACPI: FACS 0x00000000D96F1F80 000040
[    0.000000] ACPI: APIC 0x00000000D96DF598 000072 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0x00000000D96DF610 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: SSDT 0x00000000D96DF650 00036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[    0.000000] ACPI: SSDT 0x00000000D96DF9C0 0009AA (v01 PmRef  Cpu0Ist  00003000 INTL 20051117)
[    0.000000] ACPI: SSDT 0x00000000D96E0370 000A92 (v01 PmRef  CpuPm    00003000 INTL 20051117)
[    0.000000] ACPI: DMAR 0x00000000D96E0E08 0000B8 (v01 INTEL  SNB      00000001 INTL 00000001)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000021f5fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x21f5f6000-0x21f5fafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000021f5fffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
[    0.000000]   node   0: [mem 0x0000000020200000-0x0000000040003fff]
[    0.000000]   node   0: [mem 0x0000000040005000-0x00000000d8e6bfff]
[    0.000000]   node   0: [mem 0x00000000da29f000-0x00000000da29ffff]
[    0.000000]   node   0: [mem 0x00000000da2e3000-0x00000000dac7ffff]
[    0.000000]   node   0: [mem 0x00000000dafdc000-0x00000000daffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000021f5fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021f5fffff]
[    0.000000] On node 0 totalpages: 2067401
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3996 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 13849 pages used for memmap
[    0.000000]   DMA32 zone: 886317 pages, LIFO batch:31
[    0.000000]   Normal zone: 18392 pages used for memmap
[    0.000000]   Normal zone: 1177088 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x00000000dba00000-0x00000000df9fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x40004000-0x40004fff]
[    0.000000] PM: Registered nosave memory: [mem 0xd8e6c000-0xd95cefff]
[    0.000000] PM: Registered nosave memory: [mem 0xd95cf000-0xd95cffff]
[    0.000000] PM: Registered nosave memory: [mem 0xd95d0000-0xd96f2fff]
[    0.000000] PM: Registered nosave memory: [mem 0xd96f3000-0xda29efff]
[    0.000000] PM: Registered nosave memory: [mem 0xda2a0000-0xda2e2fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdac80000-0xdafdbfff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb000000-0xdb7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb800000-0xdf9fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffff97795f200000 s437952 r8192 d28992 u524288
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2035075
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-5-rt-amd64 root=/dev/sdb1 ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 8031036K/8269604K available (6336K kernel code, 1152K rwdata, 2888K rodata, 1668K init, 968K bss, 238568K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS:33024 nr_irqs:456 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3400.372 MHz processor
[    0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 6800.74 BogoMIPS (lpj=13601488)
[    0.000003] pid_max: default: 32768 minimum: 301
[    0.000010] ACPI: Core revision 20160831
[    0.003805] ACPI: 4 ACPI AML tables successfully acquired and loaded
[    0.003822] Security Framework initialized
[    0.003822] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.003826] AppArmor: AppArmor disabled by boot time parameter
[    0.004597] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[    0.006604] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.007245] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.007252] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.007445] CPU: Physical Processor ID: 0
[    0.007446] CPU: Processor Core ID: 0
[    0.007449] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.007449] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.007452] mce: CPU supports 9 MCE banks
[    0.007458] CPU0: Thermal monitoring enabled (TM1)
[    0.007467] process: using mwait in idle threads
[    0.007469] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.007469] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.007772] Freeing SMP alternatives memory: 24K
[    0.008564] ftrace: allocating 25161 entries in 99 pages
[    0.016662] smpboot: Max logical packages: 1
[    0.016666] DMAR: Host address width 36
[    0.016667] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.016675] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
[    0.016675] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.016678] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
[    0.016679] DMAR: RMRR base: 0x000000d9566000 end: 0x000000d9572fff
[    0.016679] DMAR: RMRR base: 0x000000db800000 end: 0x000000df9fffff
[    0.016681] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.016681] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.016682] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.016922] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.016923] x2apic enabled
[    0.016927] Switched APIC routing to cluster x2apic.
[    0.017346] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.057042] TSC deadline timer enabled
[    0.057043] smpboot: CPU0: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[    0.057046] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.057062] ... version:                3
[    0.057062] ... bit width:              48
[    0.057062] ... generic registers:      8
[    0.057063] ... value mask:             0000ffffffffffff
[    0.057063] ... max period:             00007fffffffffff
[    0.057064] ... fixed-purpose events:   3
[    0.057064] ... event mask:             00000007000000ff
[    0.113226] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.165160] x86: Booting SMP configuration:
[    0.165162] .... node  #0, CPUs:      #1 #2 #3
[    0.255930] x86: Booted up 1 node, 4 CPUs
[    0.255931] smpboot: Total of 4 processors activated (27202.97 BogoMIPS)
[    0.258315] devtmpfs: initialized
[    0.258363] x86/mm: Memory block size: 128MB
[    0.260332] PM: Registering ACPI NVS region [mem 0xd95d0000-0xd96f2fff] (1191936 bytes)
[    0.260345] PM: Registering ACPI NVS region [mem 0xda2a0000-0xda2e2fff] (274432 bytes)
[    0.260385] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.260399] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.260436] pinctrl core: initialized pinctrl subsystem
[    0.260526] NET: Registered protocol family 16
[    0.260681] cpuidle: using governor ladder
[    0.260703] cpuidle: using governor menu
[    0.260726] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.260727] ACPI: bus type PCI registered
[    0.260728] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.260779] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.260780] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.260785] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.260847] PCI: Using configuration type 1 for base access
[    0.260925] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.260963] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.261672] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.261796] ACPI: Added _OSI(Module Device)
[    0.261797] ACPI: Added _OSI(Processor Device)
[    0.261797] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.261798] ACPI: Added _OSI(Processor Aggregator Device)
[    0.261959] ACPI: Executed 1 blocks of module-level executable AML code
[    0.264781] ACPI: Dynamic OEM Table Load:
[    0.264785] ACPI: SSDT 0xFFFF977954F24000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
[    0.264999] ACPI: Dynamic OEM Table Load:
[    0.265002] ACPI: SSDT 0xFFFF977954A53800 000303 (v01 PmRef  ApIst    00003000 INTL 20051117)
[    0.265149] ACPI: Dynamic OEM Table Load:
[    0.265152] ACPI: SSDT 0xFFFF977954929E00 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
[    0.265813] ACPI: Interpreter enabled
[    0.265828] ACPI: (supports S0 S3 S4 S5)
[    0.265828] ACPI: Using IOAPIC for interrupt routing
[    0.265848] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.270777] ACPI: Power Resource [FN00] (off)
[    0.270838] ACPI: Power Resource [FN01] (off)
[    0.270898] ACPI: Power Resource [FN02] (off)
[    0.270956] ACPI: Power Resource [FN03] (off)
[    0.271015] ACPI: Power Resource [FN04] (off)
[    0.271414] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.271418] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.271571] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[    0.271663] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.271664] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.271974] PCI host bridge to bus 0000:00
[    0.271975] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.271976] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.271977] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.271978] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.271979] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.271979] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.271980] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.271981] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.271982] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.271982] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
[    0.271983] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.271989] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[    0.272065] pci 0000:00:02.0: [8086:0152] type 00 class 0x030000
[    0.272072] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[    0.272076] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.272078] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.272168] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[    0.272185] pci 0000:00:14.0: reg 0x10: [mem 0xf7d00000-0xf7d0ffff 64bit]
[    0.272250] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.272290] pci 0000:00:14.0: System wakeup disabled by ACPI
[    0.272322] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[    0.272340] pci 0000:00:16.0: reg 0x10: [mem 0xf7d1a000-0xf7d1a00f 64bit]
[    0.272408] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.272482] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[    0.272498] pci 0000:00:1a.0: reg 0x10: [mem 0xf7d18000-0xf7d183ff]
[    0.272576] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.272626] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.272657] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[    0.272672] pci 0000:00:1b.0: reg 0x10: [mem 0xf7d10000-0xf7d13fff 64bit]
[    0.272739] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.272784] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.272813] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[    0.272883] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.272927] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.272959] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[    0.273029] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.273073] pci 0000:00:1c.4: System wakeup disabled by ACPI
[    0.273102] pci 0000:00:1c.5: [8086:1e1a] type 01 class 0x060400
[    0.273172] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.273215] pci 0000:00:1c.5: System wakeup disabled by ACPI
[    0.273244] pci 0000:00:1c.6: [8086:1e1c] type 01 class 0x060400
[    0.273314] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.273357] pci 0000:00:1c.6: System wakeup disabled by ACPI
[    0.273388] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[    0.273404] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d17000-0xf7d173ff]
[    0.273481] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.273531] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.273563] pci 0000:00:1f.0: [8086:1e4a] type 00 class 0x060100
[    0.273720] pci 0000:00:1f.2: [8086:1e02] type 00 class 0x010601
[    0.273733] pci 0000:00:1f.2: reg 0x10: [io  0xf0b0-0xf0b7]
[    0.273739] pci 0000:00:1f.2: reg 0x14: [io  0xf0a0-0xf0a3]
[    0.273745] pci 0000:00:1f.2: reg 0x18: [io  0xf090-0xf097]
[    0.273751] pci 0000:00:1f.2: reg 0x1c: [io  0xf080-0xf083]
[    0.273757] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[    0.273764] pci 0000:00:1f.2: reg 0x24: [mem 0xf7d16000-0xf7d167ff]
[    0.273800] pci 0000:00:1f.2: PME# supported from D3hot
[    0.273862] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[    0.273875] pci 0000:00:1f.3: reg 0x10: [mem 0xf7d15000-0xf7d150ff 64bit]
[    0.273893] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[    0.274010] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.274087] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.274109] pci 0000:02:00.0: reg 0x10: [io  0xe000-0xe0ff]
[    0.274141] pci 0000:02:00.0: reg 0x18: [mem 0xf0104000-0xf0104fff 64bit pref]
[    0.274160] pci 0000:02:00.0: reg 0x20: [mem 0xf0100000-0xf0103fff 64bit pref]
[    0.274274] pci 0000:02:00.0: supports D1 D2
[    0.274275] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.274323] pci 0000:02:00.0: System wakeup disabled by ACPI
[    0.848864] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.848869] pci 0000:00:1c.4:   bridge window [io  0xe000-0xefff]
[    0.848879] pci 0000:00:1c.4:   bridge window [mem 0xf0100000-0xf01fffff 64bit pref]
[    0.849004] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[    0.849026] pci 0000:03:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.849059] pci 0000:03:00.0: reg 0x18: [mem 0xf0004000-0xf0004fff 64bit pref]
[    0.849078] pci 0000:03:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[    0.849194] pci 0000:03:00.0: supports D1 D2
[    0.849194] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.849242] pci 0000:03:00.0: System wakeup disabled by ACPI
[    0.864870] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.864875] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.864884] pci 0000:00:1c.5:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.864999] pci 0000:04:00.0: [8086:0887] type 00 class 0x028000
[    0.865039] pci 0000:04:00.0: reg 0x10: [mem 0xf7c00000-0xf7c01fff 64bit]
[    0.865236] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[    0.865287] pci 0000:04:00.0: System wakeup disabled by ACPI
[    0.876879] pci 0000:00:1c.6: PCI bridge to [bus 04]
[    0.876887] pci 0000:00:1c.6:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.877293] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.877332] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.877367] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 10 11 12 14 15)
[    0.877401] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.877436] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.877470] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.877505] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.877539] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.877720] ACPI: Enabled 4 GPEs in block 00 to 3F
[    0.877820] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.877821] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.877825] vgaarb: loaded
[    0.877825] vgaarb: bridge control possible 0000:00:02.0
[    0.877877] PCI: Using ACPI for IRQ routing
[    0.879280] PCI: pci_cache_line_size set to 64 bytes
[    0.879326] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[    0.879327] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
[    0.879327] e820: reserve RAM buffer [mem 0xd8e6c000-0xdbffffff]
[    0.879328] e820: reserve RAM buffer [mem 0xda2a0000-0xdbffffff]
[    0.879329] e820: reserve RAM buffer [mem 0xdac80000-0xdbffffff]
[    0.879330] e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
[    0.879331] e820: reserve RAM buffer [mem 0x21f600000-0x21fffffff]
[    0.879451] clocksource: Switched to clocksource refined-jiffies
[    0.886378] VFS: Disk quotas dquot_6.6.0
[    0.886394] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.886458] pnp: PnP ACPI init
[    0.886549] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.886553] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.886615] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.886616] system 00:01: [io  0x0200-0x020f] has been reserved
[    0.886617] system 00:01: [io  0xffff] has been reserved
[    0.886618] system 00:01: [io  0xffff] has been reserved
[    0.886619] system 00:01: [io  0x0400-0x0453] has been reserved
[    0.886620] system 00:01: [io  0x0458-0x047f] has been reserved
[    0.886621] system 00:01: [io  0x0500-0x057f] has been reserved
[    0.886623] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.886643] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.886683] system 00:03: [io  0x0454-0x0457] has been reserved
[    0.886685] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.886782] system 00:04: [io  0x0a00-0x0a0f] has been reserved
[    0.886783] system 00:04: [io  0x0a30-0x0a3f] has been reserved
[    0.886784] system 00:04: [io  0x0a20-0x0a2f] has been reserved
[    0.886786] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.886820] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    0.886956] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.886958] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.887116] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.887117] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.887118] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.887119] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.887120] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.887121] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.887122] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.887123] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.887124] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[    0.887125] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.887126] system 00:07: [mem 0xdfa00000-0xdfa00fff] has been reserved
[    0.887128] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.887231] system 00:08: [mem 0x20000000-0x201fffff] has been reserved
[    0.887232] system 00:08: [mem 0x40004000-0x40004fff] has been reserved
[    0.887234] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.887247] pnp: PnP ACPI: found 9 devices
[    0.892877] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.892884] clocksource: Switched to clocksource acpi_pm
[    0.892915] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.892925] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.892927] pci 0000:00:1c.4:   bridge window [io  0xe000-0xefff]
[    0.892933] pci 0000:00:1c.4:   bridge window [mem 0xf0100000-0xf01fffff 64bit pref]
[    0.892938] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.892939] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.892945] pci 0000:00:1c.5:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.892950] pci 0000:00:1c.6: PCI bridge to [bus 04]
[    0.892953] pci 0000:00:1c.6:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.892961] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.892962] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.892963] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.892963] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.892964] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.892965] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.892966] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.892967] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
[    0.892967] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
[    0.892968] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
[    0.892969] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.892970] pci_bus 0000:02: resource 2 [mem 0xf0100000-0xf01fffff 64bit pref]
[    0.892971] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.892972] pci_bus 0000:03: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.892973] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.893039] NET: Registered protocol family 2
[    0.893175] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.893465] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[    0.893989] TCP: Hash tables configured (established 65536 bind 65536)
[    0.894038] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[    0.894147] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[    0.894266] NET: Registered protocol family 1
[    0.894285] pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
[    0.894297] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.941053] PCI: CLS mismatch (64 != 32), using 64 bytes
[    0.941100] Unpacking initramfs...
[    1.218591] Freeing initrd memory: 23336K
[    1.218628] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.218630] software IO TLB [mem 0xd4e6c000-0xd8e6c000] (64MB) mapped at [ffff977814e6c000-ffff977818e6bfff]
[    1.218901] audit: initializing netlink subsys (disabled)
[    1.218914] audit: type=2000 audit(1533219050.663:1): initialized
[    1.219270] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[    1.220563] zbud: loaded
[    1.221205] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.221227] io scheduler noop registered
[    1.221228] io scheduler deadline registered
[    1.221250] io scheduler cfq registered (default)
[    1.221780] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.221783] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.221794] intel_idle: MWAIT substates: 0x1120
[    1.221795] intel_idle: v0.4.1 model 0x3A
[    1.221888] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.221995] GHES: HEST is not enabled!
[    1.222032] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.222279] Linux agpgart interface v0.103
[    1.222346] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.222346] AMD IOMMUv2 functionality not available on this system
[    1.222581] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.222581] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.222755] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.222833] mousedev: PS/2 mouse device common for all mice
[    1.222864] rtc_cmos 00:02: RTC can wake from S4
[    1.222977] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    1.223041] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram
[    1.223047] intel_pstate: Intel P-state driver initializing
[    1.223929] NET: Registered protocol family 10
[    1.224283] mip6: Mobile IPv6
[    1.224286] NET: Registered protocol family 17
[    1.224289] mpls_gso: MPLS GSO support
[    1.224596] microcode: sig=0x306a9, pf=0x2, revision=0x1c
[    1.224722] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.224931] registered taskstats version 1
[    1.224959] zswap: loaded using pool lzo/zbud
[    1.225003] ima: No TPM chip found, activating TPM-bypass!
[    1.225427] rtc_cmos 00:02: setting system clock to 2018-08-02 14:10:51 UTC (1533219051)
[    1.225542] PM: Hibernation image not present or could not be loaded.
[    1.227716] Freeing unused kernel memory: 1668K
[    1.227717] Write protecting the kernel read-only data: 12288k
[    1.228804] Freeing unused kernel memory: 1840K
[    1.232959] Freeing unused kernel memory: 1208K
[    1.240689] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.241729] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.263426] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.263543] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.263556] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.264849] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.264931] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.266308] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.266331] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.266812] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.266896] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.266985] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.317890] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.317897] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.321371] ACPI: bus type USB registered
[    1.321392] usbcore: registered new interface driver usbfs
[    1.321403] usbcore: registered new interface driver hub
[    1.321420] usbcore: registered new device driver usb
[    1.324725] SCSI subsystem initialized
[    1.326000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.327624] ehci-pci: EHCI PCI platform driver
[    1.329682] r8169 0000:02:00.0 eth0: RTL8168evl/8111evl at 0xffffb7b4814a5000, 94:de:80:67:8c:da, XID 0c900800 IRQ 26
[    1.329683] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.329696] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.329699] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.330071] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.330442] r8169 0000:03:00.0 eth1: RTL8168evl/8111evl at 0xffffb7b4814ad000, 94:de:80:67:8c:dc, XID 0c900800 IRQ 27
[    1.330444] r8169 0000:03:00.0 eth1: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.331226] thermal LNXTHERM:00: registered as thermal_zone0
[    1.331227] ACPI: Thermal Zone [TZ00] (28 C)
[    1.332708] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    1.332794] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.332807] ehci-pci 0000:00:1a.0: debug port 2
[    1.334129] thermal LNXTHERM:01: registered as thermal_zone1
[    1.334131] ACPI: Thermal Zone [TZ01] (30 C)
[    1.336696] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    1.336735] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7d18000
[    1.343139] libata version 3.00 loaded.
[    1.348912] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.349197] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.349198] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.349199] usb usb1: Product: EHCI Host Controller
[    1.349200] usb usb1: Manufacturer: Linux 4.9.0-5-rt-amd64 ehci_hcd
[    1.349201] usb usb1: SerialNumber: 0000:00:1a.0
[    1.351124] AVX version of gcm_enc/dec engaged.
[    1.351125] AES CTR mode by8 optimization enabled
[    1.357996] hub 1-0:1.0: USB hub found
[    1.358008] hub 1-0:1.0: 2 ports detected
[    1.360358] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.360369] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.360842] r8169 0000:03:00.0 enp3s0: renamed from eth1
[    1.361460] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x0000b930
[    1.361464] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.361614] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.361615] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.361616] usb usb2: Product: xHCI Host Controller
[    1.361617] usb usb2: Manufacturer: Linux 4.9.0-5-rt-amd64 xhci-hcd
[    1.361618] usb usb2: SerialNumber: 0000:00:14.0
[    1.361750] hub 2-0:1.0: USB hub found
[    1.361764] hub 2-0:1.0: 4 ports detected
[    1.362064] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.362067] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    1.362129] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[    1.362130] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.362131] usb usb3: Product: xHCI Host Controller
[    1.362132] usb usb3: Manufacturer: Linux 4.9.0-5-rt-amd64 xhci-hcd
[    1.362133] usb usb3: SerialNumber: 0000:00:14.0
[    1.362245] hub 3-0:1.0: USB hub found
[    1.362257] hub 3-0:1.0: 4 ports detected
[    1.362593] ahci 0000:00:1f.2: version 3.0
[    1.362936] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[    1.362958] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x8 impl SATA mode
[    1.362960] ahci 0000:00:1f.2: flags: 64bit ncq stag led clo pio slum part ems sxs apst
[    1.364981] scsi host0: ahci
[    1.365066] scsi host1: ahci
[    1.365141] scsi host2: ahci
[    1.365212] scsi host3: ahci
[    1.365282] scsi host4: ahci
[    1.365352] scsi host5: ahci
[    1.365391] ata1: DUMMY
[    1.365391] ata2: DUMMY
[    1.365392] ata3: DUMMY
[    1.365393] ata4: SATA max UDMA/133 abar m2048@0xf7d16000 port 0xf7d16280 irq 29
[    1.365394] ata5: DUMMY
[    1.365394] ata6: DUMMY
[    1.365535] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    1.365538] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[    1.365548] ehci-pci 0000:00:1d.0: debug port 2
[    1.369440] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    1.369524] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7d17000
[    1.373059] r8169 0000:02:00.0 enp2s0: renamed from eth0
[    1.384920] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    1.385193] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    1.385194] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.385195] usb usb4: Product: EHCI Host Controller
[    1.385196] usb usb4: Manufacturer: Linux 4.9.0-5-rt-amd64 ehci_hcd
[    1.385197] usb usb4: SerialNumber: 0000:00:1d.0
[    1.385406] hub 4-0:1.0: USB hub found
[    1.385445] hub 4-0:1.0: 2 ports detected
[    1.679940] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.681977] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[    1.682131] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT3._GTF] (Node ffff9779569c7230), AE_NOT_FOUND (20160831/psparse-543)
[    1.682468] ata4.00: HPA detected: current 625140335, native 625142448
[    1.682637] ata4.00: ATA-8: SAMSUNG HD321KJ, CP100-11, max UDMA7
[    1.682641] ata4.00: 625140335 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.684692] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[    1.684843] ACPI Error: Method parse/execution failed
[    1.684915] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.684947] [\_SB.PCI0.SAT0.SPT3._GTF] (Node ffff9779569c7230)
[    1.684980] , AE_NOT_FOUND (20160831/psparse-543)
[    1.685184] ata4.00: configured for UDMA/133
[    1.688922] usb 2-2: new high-speed USB device number 2 using xhci_hcd
[    1.689672] scsi 3:0:0:0: Direct-Access     ATA      SAMSUNG HD321KJ  0-11 PQ: 0 ANSI: 5
[    1.712947] usb 4-1: new high-speed USB device number 2 using ehci-pci
[    1.750744] sd 3:0:0:0: [sda] 625140335 512-byte logical blocks: (320 GB/298 GiB)
[    1.750829] sd 3:0:0:0: [sda] Write Protect is off
[    1.750831] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.750868] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.757294]  sda: sda1
[    1.758095] sd 3:0:0:0: [sda] Attached SCSI removable disk
[    1.833624] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    1.833628] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.834045] hub 1-1:1.0: USB hub found
[    1.834221] hub 1-1:1.0: 6 ports detected
[    1.861621] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
[    1.861623] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.861957] hub 4-1:1.0: USB hub found
[    1.862031] hub 4-1:1.0: 8 ports detected
[    2.017277] usb 2-2: New USB device found, idVendor=0930, idProduct=6545
[    2.017281] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.017282] usb 2-2: Product: DataTraveler 3.0
[    2.017284] usb 2-2: Manufacturer: Kingston
[    2.017285] usb 2-2: SerialNumber: 08606E6D4080EF41670DEDAE
[    2.020433] usb-storage 2-2:1.0: USB Mass Storage device detected
[    2.020564] scsi host6: usb-storage 2-2:1.0
[    2.020674] usbcore: registered new interface driver usb-storage
[    2.021162] usbcore: registered new interface driver uas
[    2.124941] usb 1-1.3: new low-speed USB device number 3 using ehci-pci
[    2.238374] usb 1-1.3: New USB device found, idVendor=1bcf, idProduct=0053
[    2.238377] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.238379] usb 1-1.3: Product: USB Optical Mouse
[    2.241965] hidraw: raw HID events driver (C) Jiri Kosina
[    2.247653] usbcore: registered new interface driver usbhid
[    2.247655] usbhid: USB HID core driver
[    2.248851] input: USB Optical Mouse  as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1BCF:0053.0001/input/input1
[    2.252913] tsc: Refined TSC clocksource calibration: 3400.351 MHz
[    2.252921] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x31039a19e37, max_idle_ns: 440795249151 ns
[    2.305290] hid-generic 0003:1BCF:0053.0001: input,hidraw0: USB HID v1.10 Keyboard [USB Optical Mouse ] on usb-0000:00:1a.0-1.3/input0
[    2.316897] usb 1-1.5: new full-speed USB device number 4 using ehci-pci
[    2.430006] usb 1-1.5: New USB device found, idVendor=8087, idProduct=07da
[    2.430010] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.146016] scsi 6:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[    3.273155] clocksource: Switched to clocksource tsc
[    4.238710] random: fast init done
[    4.239635] sd 6:0:0:0: [sdb] 30497664 512-byte logical blocks: (15.6 GB/14.5 GiB)
[    4.239837] sd 6:0:0:0: [sdb] Write Protect is off
[    4.239840] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[    4.240010] sd 6:0:0:0: [sdb] No Caching mode page found
[    4.240012] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[    4.266924]  sdb: sdb1 sdb2 < sdb5 >
[    4.268653] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[    5.076655] PM: Starting manual resume from disk
[    5.076659] PM: Hibernation image partition 8:21 present
[    5.076660] PM: Looking for hibernation image.
[    5.077154] PM: Image not found (code -22)
[    5.077156] PM: Hibernation image not present or could not be loaded.
[    5.225693] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[    5.553065] ip_tables: (C) 2000-2006 Netfilter Core Team
[    5.572302] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    5.572463] systemd[1]: Detected architecture x86-64.
[    5.572916] systemd[1]: Set hostname to <mc500vsystem>.
[    5.729677] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    5.729730] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    5.730110] systemd[1]: Reached target Remote File Systems.
[    5.730197] systemd[1]: Listening on Syslog Socket.
[    5.730342] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.730375] systemd[1]: Listening on udev Kernel Socket.
[    5.730439] systemd[1]: Listening on Journal Audit Socket.
[    5.829794] lp: driver loaded but no devices found
[    5.848733] ppdev: user-space parallel port driver
[    5.882762] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
[    5.891547] systemd-journald[276]: Received request to flush runtime journal from PID 1
[    6.190237] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    6.190240] ACPI: Power Button [PWRB]
[    6.190282] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    6.190284] ACPI: Power Button [PWRF]
[    6.246239] EDAC MC: Ver: 3.0.0
[    6.250845] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    6.263788] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20160831/utaddress-247)
[    6.263792] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    6.263794] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
[    6.263796] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    6.263796] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
[    6.263798] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    6.263799] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000051F (\LED) (20160831/utaddress-247)
[    6.263801] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
[    6.263802] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    6.263803] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    6.296411] EDAC ie31200: No ECC support
[    6.356932] [drm] Initialized
[    6.431930] sd 3:0:0:0: Attached scsi generic sg0 type 0
[    6.431954] sd 6:0:0:0: Attached scsi generic sg1 type 0
[    6.515704] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC892: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    6.515706] snd_hda_codec_realtek hdaudioC0D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    6.515707] snd_hda_codec_realtek hdaudioC0D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    6.515707] snd_hda_codec_realtek hdaudioC0D2:    mono: mono_out=0x0
[    6.515708] snd_hda_codec_realtek hdaudioC0D2:    dig-out=0x11/0x1e
[    6.515709] snd_hda_codec_realtek hdaudioC0D2:    inputs:
[    6.515710] snd_hda_codec_realtek hdaudioC0D2:      Front Mic=0x19
[    6.515711] snd_hda_codec_realtek hdaudioC0D2:      Rear Mic=0x18
[    6.515712] snd_hda_codec_realtek hdaudioC0D2:      Line=0x1a
[    6.618488] Intel(R) Wireless WiFi driver for Linux
[    6.618489] Copyright(c) 2003- 2015 Intel Corporation
[    6.618587] iwlwifi 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[    6.638220] iwlwifi 0000:04:00.0: firmware: direct-loading firmware iwlwifi-2030-6.ucode
[    6.638345] iwlwifi 0000:04:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[    6.676548] iwlwifi 0000:04:00.0: CONFIG_IWLWIFI_DEBUG disabled
[    6.676550] iwlwifi 0000:04:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
[    6.676550] iwlwifi 0000:04:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
[    6.676551] iwlwifi 0000:04:00.0: Detected Intel(R) Centrino(R) Wireless-N 2230 BGN, REV=0xC8
[    6.678583] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    6.684981] input: PC Speaker as /devices/platform/pcspkr/input/input12
[    6.686087] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[    6.686088] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[    6.686088] RAPL PMU: hw unit of domain package 2^-16 Joules
[    6.686089] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[    6.686483] iTCO_vendor_support: vendor-support=0
[    6.702179] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[    6.702519] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    6.702546] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[    6.727666] [drm] Memory usable by graphics device = 2048M
[    6.727668] [drm] Replacing VGA console driver
[    6.728138] Console: switching to colour dummy device 80x25
[    6.735288] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    6.735289] [drm] Driver supports precise vblank timestamp query.
[    6.744834] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    6.769697] random: crng init done
[    6.789043] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    6.789236] acpi device:49: registered as cooling_device9
[    6.789284] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
[    6.789364] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    6.789369] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    6.791797] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[    6.792710] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[    6.792752] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[    6.792814] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    6.792870] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    6.793017] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    6.793101] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    6.793278] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    6.793317] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    6.793355] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    6.796840] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
[    6.894769] fbcon: inteldrmfb (fb0) is primary device
[    6.937421] Bluetooth: Core ver 2.22
[    6.937431] NET: Registered protocol family 31
[    6.937432] Bluetooth: HCI device and connection manager initialized
[    6.937434] Bluetooth: HCI socket layer initialized
[    6.937435] Bluetooth: L2CAP socket layer initialized
[    6.937440] Bluetooth: SCO socket layer initialized
[    7.056688] Console: switching to colour frame buffer device 160x64
[    7.070330] usbcore: registered new interface driver btusb
[    7.075336] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    7.157379] intel_rapl: Found RAPL domain package
[    7.157381] intel_rapl: Found RAPL domain core
[    7.157382] intel_rapl: Found RAPL domain uncore
[    7.393979] Adding 8268796k swap on /dev/sdb5.  Priority:-1 extents:1 across:8268796k FS
[    7.638643] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.638645] Bluetooth: BNEP filters: protocol multicast
[    7.638647] Bluetooth: BNEP socket layer initialized
[    8.416743] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    8.421434] r8169 0000:02:00.0: firmware: direct-loading firmware rtl_nic/rtl8168e-3.fw
[    8.530957] r8169 0000:02:00.0 enp2s0: link down
[    8.531002] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    8.534114] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[    8.647001] r8169 0000:03:00.0 enp3s0: link down
[    8.647055] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[    8.651109] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[    8.652925] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    8.660644] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    8.660731] iwlwifi 0000:04:00.0: Radio type=0x2-0x0-0x0
[    8.914435] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    8.922168] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    8.922256] iwlwifi 0000:04:00.0: Radio type=0x2-0x0-0x0
[    8.986901] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[    9.063322] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    9.071054] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    9.071142] iwlwifi 0000:04:00.0: Radio type=0x2-0x0-0x0
[    9.326539] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    9.334270] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[    9.334358] iwlwifi 0000:04:00.0: Radio type=0x2-0x0-0x0
[    9.396149] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[    9.552820] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[   10.515511] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[   10.523248] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[   10.523336] iwlwifi 0000:04:00.0: Radio type=0x2-0x0-0x0
[   10.778488] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[   10.786219] iwlwifi 0000:04:00.0: L1 Disabled - LTR Disabled
[   10.786307] iwlwifi 0000:04:00.0: Radio type=0x2-0x0-0x0
[   10.853337] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[   10.907075] wlp4s0: authenticate with 44:6e:e5:d1:da:3d
[   10.910303] wlp4s0: send auth to 44:6e:e5:d1:da:3d (try 1/3)
[   10.912991] wlp4s0: authenticated
[   10.916873] wlp4s0: associate with 44:6e:e5:d1:da:3d (try 1/3)
[   10.921505] wlp4s0: RX AssocResp from 44:6e:e5:d1:da:3d (capab=0x401 status=0 aid=2)
[   10.941444] wlp4s0: associated
[   10.941486] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[   82.486514] Chrome_ChildThr[1186]: segfault at 0 ip 00005626c8e47f41 sp 00007f3346ffe320 error 6 in plugin-container[5626c8e43000+1b000]
[  154.154879] wlp4s0: authenticate with 44:6e:e5:d1:da:3d
[  154.157797] wlp4s0: send auth to 44:6e:e5:d1:da:3d (try 1/3)
[  154.161321] wlp4s0: authenticated
[  154.164696] wlp4s0: associate with 44:6e:e5:d1:da:3d (try 1/3)
[  154.169608] wlp4s0: RX AssocResp from 44:6e:e5:d1:da:3d (capab=0x401 status=0 aid=2)
[  154.189454] wlp4s0: associated
[  202.552877] usb 1-1.3: USB disconnect, device number 3
[  202.881965] usb 1-1.3: new low-speed USB device number 5 using ehci-pci
[  202.994970] usb 1-1.3: New USB device found, idVendor=1bcf, idProduct=0053
[  202.994974] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  202.994975] usb 1-1.3: Product: USB Optical Mouse
[  203.001038] input: USB Optical Mouse  as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1BCF:0053.0002/input/input16
[  203.058303] hid-generic 0003:1BCF:0053.0002: input,hidraw0: USB HID v1.10 Keyboard [USB Optical Mouse ] on usb-0000:00:1a.0-1.3/input0
[  204.931224] r8169 0000:02:00.0 enp2s0: link up
[  204.931234] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[  242.488584] usb 1-1.3: USB disconnect, device number 5
[  242.811606] usb 1-1.3: new low-speed USB device number 6 using ehci-pci
[  242.924709] usb 1-1.3: New USB device found, idVendor=1bcf, idProduct=0053
[  242.924711] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  242.924712] usb 1-1.3: Product: USB Optical Mouse
[  242.930265] input: USB Optical Mouse  as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1BCF:0053.0003/input/input17
[  242.988025] hid-generic 0003:1BCF:0053.0003: input,hidraw0: USB HID v1.10 Keyboard [USB Optical Mouse ] on usb-0000:00:1a.0-1.3/input0
[ 1641.050999] fuse init (API version 7.26)
[ 2111.603541] isofs_fill_super: bread failed, dev=sdb2, iso_blknum=16, block=32
Last edit: 03 Aug 2018 16:00 by andypugh.
03 Aug 2018 16:04 #115530 by andypugh
is the problem.
Line 9 in the file machine2.hal
This might mean that the 7i92 driver has not found the 7i92. Try commenting-out that line and see if it errors-out at the next mention of the 7i92.
03 Aug 2018 16:06 #115531 by andypugh
Your "loadrt hm2_eth" line in the HAL seems to lack the "board_ip=" entry. This is probably the problem.
  • Moderator
  • Moderator
03 Aug 2018 16:17 #115533 by tommylight
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx"
That is the complete line for 7i92/7i77
Time to create page: 0.345 seconds
