Hydraulic Tube Bender - Manual to CNC Conversion
20 Jul 2019 13:30 #139963 by JimPanski
Replied by JimPanski on topic Hydraulic Tube Bender - Manual to CNC Conversion
Hi John,
exactly. For thin wall tubes a mandrel is needed.
As i wrote also in my first post, the actual manual machine has its only axis measured by a pot. Its mounted under the machines bending head and 10:1 geared.
When you choose a bending angle on the control panel, its also done by such a pot. (those 8 black knobs you can see on the first link). When both values are equal, the machine knows that the bending angle is reached.
For now i have no clue how to do this in the future with linuxcnc and the ttl encoder.
I have to preset the desired angle and the axis has to move later on (with the bending start signal). The output for the motion valve also cant be high when the machine has reached its fully back position although the encoder maybe flickers (because of some eventually wobble caused by the chain which drives the bending arm)
I hope you understand my problem and maybe you can get me a hint!
Conny
22 Jul 2019 19:12 #140221 by BigJohnT
The encoder would be the feedback from each axis that moves. To move an axis to a new position the output for that direction would turn on until the encoder has the correct value. The angle to encoder counts is the scale of that axis.
How many axes does your machine have?
JT
23 Jul 2019 09:38 #140281 by JimPanski
Hi John,
the problem its only about the C axis. when i have the machine upgraded to cnc the tube transport unit will make the Z and A axis. (but here i will go with a stepper system with encoders, so there is everything clear to me)
So what i tried to say in my last post. the output for my c axis has to be low until the "bending start signal" comes true.
Also there are other things which have to block the movement (like tool has to be clamped and mandrel position and so on) <=but this works already in my ladder program.
I looked alredy in the docs for the motion or axis pins, but didnt find a solution for interrupting the movement with a presetted position. i am not sure if the spindle is at speed signal is a good way to solve this.
25 Jul 2019 16:06 #140538 by BigJohnT
I'm not really following you, are you going to run the machine using just classicladder and hal?
I thought it would be just a normal machine and the G code would be something like this:
G61.1 ; set exact stop mode
M100 ; clamp tube
Z-10.25 ; move tube out
C25 ; bend 25 degrees
C0 ; move bender back
Z-25.5 ; move tube out
A90 ; rotate tube
C45 ; make another bend
C0; move bender back
M101 : release tube
M2 ; end program
25 Jul 2019 20:15 #140562 by JimPanski
Hi John,
yes and no. I want to have 3 different modes.
-A manual mode for eg. setting up the tooling, where every (hydraulic) movement is made because of a button press on the panel.
-A automatic mode (basicly for single bends) which starts the bending sequence by touching the footswitch.
-And the "new" one: Bending sequences after a bending table with the use of the added Z and A axis
My manual and auto mode are already working so far in CL. (because i simple reused the existing code). Now i have to adapt at least the C axis output to work by gcode. (also to use later the bending table in the "cnc" mode)
Imho the bending sequence or at least C axis movement has to be done with CL because of dependencies with other tool components.
Please look at this . The bending axis only can move if the tool is clamped, the pressure die is attached and the mandrel is in position. Also the pressure die has to move by hydraulic towards the bend (to push the material for better bending quality). On top of that the mandrel has to be pulled back in generally early. Mostly at 5deg before the desired bending angle is reached.
So for i have no clue how the signal for my bending axis valves can be attached to do the movement correct.
I hope its now a bit better comprehensible for you what i was trying to say.
Thank you
Conny
26 Jul 2019 11:52 #140645 by BigJohnT
I'm not sure how you could use a bending table in G code.
In automatic mode how do you set the bend angle?
You might attach your configuration files in a zip.
JT
26 Jul 2019 12:51 #140649 by JimPanski
Hi John,
andypugh did this in the other thread i linked in the first post.
BUT: i didnt get it with the Python code in "bender.py" ...maybe andy can help here.
The auto mode gets this value presetted by the pot on the control table. Therefore i was asking the question in post #140281 how to do this in the future by linuxcnc.
For the config files: do you see chances to get it with german named I/O´s?
Conny
26 Jul 2019 23:38 - 26 Jul 2019 23:40 #140700 by BigJohnT
Hi John,
Conny
if you mean this post from Andy
Alternatively, an input filter file could convert your table to G-code, then you would execute the G-code.
your still using G code to run the machine.
The pin names are hard coded into the hostmot2 c files.
JT
Last edit: 26 Jul 2019 23:40 by BigJohnT.
28 Jul 2019 21:28 #140841 by andypugh
HSo for i have no clue how the signal for my bending axis valves can be attached to do the movement correct.
PID.
Exactly like a servo axis. Is the hydraulic valve proprtional?
28 Jul 2019 21:29 #140842 by andypugh
PID.
Exactly like a servo axis. Is the hydraulic valve proportional?
The following user(s) said Thank You: Todd Zuercher, JimPanski
Time to create page: 0.180 seconds
