Mechanical ATC
- prochj51
25 Mar 2020 11:44 #161417
by prochj51
Mechanical ATC was created by prochj51
I would like to ask you if any of you have experience with Automatic tool changer WITHOUT need of pneumatic device.
I have not seen any such a machine so far, but I would expect it is possible when the lever torque for tightening
the tool is high enough.
I want to avoid the pneumatics due to the money issue.
Thanks for ideas.
Jiri
Thanks for ideas.
Jiri
- bbsr_5a
- Thank you received: 106
25 Mar 2020 11:48 #161418
by bbsr_5a
Replied by bbsr_5a on topic Mechanical ATC
hi
the pneumatic is to take out the tool not only the lamp fix
the tool will stick on mechanical and may take the complete ATC with it to the next gcode line
there are Manuell mecanicel tool changers that provide your need as you explain
so yu change the tool yourself with the Clamp/Holder so all tool length are in the system
you can get a NOICE to informe at the toolchange so from office you kow when and dont need to wait
- prochj51
25 Mar 2020 12:33 #161422
by prochj51
Replied by prochj51 on topic Mechanical ATC
And is there any automatic mechanical tool changer?
- Thank you received: 7496
25 Mar 2020 12:40 #161423
Replied by tommylight on topic Mechanical ATC
- Thank you received: 2181
25 Mar 2020 13:36 #161429
Replied by cmorley on topic Mechanical ATC
I saw a neat video of one DIY that used the tool caddy and the way movement to break loose the collet nut, then spun the spindle to unwind the collet...did the reverse to tighten. The tool caddy's holes were made hex shape to capture the nut.
Chris
Chris
- prochj51
25 Mar 2020 19:20 #161483
by prochj51
Sounds interesting, I will do more research.
Thank you
Jiri
Thank you
Jiri
- prochj51
25 Mar 2020 19:21 - 25 Mar 2020 19:22 #161484
by prochj51
Last edit: 25 Mar 2020 19:22 by prochj51.
- prochj51
25 Mar 2020 19:22 #161485
by prochj51
- prochj51
25 Mar 2020 19:23 #161487
by prochj51
These tool changers have pneumatic spindles, I want to make one without pneumatics
www.google.com/search?sxsrf=ALeKk03IT7zW......0i131.RCnX2FFgsYM
25 Mar 2020 19:52 #161493
The one that Andy mentioned but i could not find it today, i did see it several times.
And you have to make it clearer what you need, do you want it without a pneumatic arm or without pneumatic in the spindle.
