Mechanical ATC
- Thank you received: 7496
25 Mar 2020 19:58 #161495
Check his other videos for other parts that make the changer.
And this is not the one Andy mentioned, i think.
Replied by tommylight on topic Mechanical ATC
25 Mar 2020 20:12 #161499
- prochj51
26 Mar 2020 13:11 - 26 Mar 2020 13:12 #161561
by prochj51
Replied by prochj51 on topic Mechanical ATC
without pneumatic in the spindle
Great videos!
Thank you
Jiri
Great videos!
Thank you
Jiri
Last edit: 26 Mar 2020 13:12 by prochj51.
28 Mar 2020 01:17 #161768
Replied by andypugh on topic Mechanical ATC
- Thank you received: 2181
28 Mar 2020 03:31 #161769
Replied by cmorley on topic Mechanical ATC
Thanks the one i was thinking of Andy
28 Mar 2020 03:38 #161770
Yes that is it !
- footpetaljones
- Thank you received: 5
28 Mar 2020 20:34 #161834
by footpetaljones
Replied by footpetaljones on topic Mechanical ATC
Robodrills and Brothers both have tool changers that don't use pneumatics.
The drawbar is compressed by an arm that goes through the headstock to a camplate on the column when Z is raised. Z raises some more to pull the tool out of the spindle, and when fully raised either a set of gears (on on the spindle nose and the other on the turret) mesh and the spindle rotates to rotate the turret, or a separate servo motor on the turret rotates to bring the next tool in line with the spindle. Then Z lowers onto the tool and doing so releases the arm holding the drawbar open.
Time to create page: 0.502 seconds
