- Thank you received: 44
andypugh wrote: S0 turns off the spindle.
I don't think it is right, but it has always been that way.
chopper79 wrote: The old method I used was motion.spindle-orient which does not seem to be supported anymore. This old method I thought I could issue an M19 only and a output was sent from my 7i77 to the vfd and the vfd would execute the orientation process the was internal to the VFD. Maybe not also, I do not recall.
This is still the current way. All that has changed is that you can now orient many spindles, and the pin name is spindle.0.orient (etc)
