Nema 34 face plate
- BeagleBrainz
- Visitor
31 May 2020 02:21 #169470
by BeagleBrainz
Replied by BeagleBrainz on topic Nema 34 face plate
Funny how no one suggested make a new one
- Thank you received: 7496
31 May 2020 08:08 #169487
Not a hobby project for sure.
Replied by tommylight on topic Nema 34 face plate
Very tight tolerances, so it's good no one suggested it!Funny how no one suggested make a new one
- macsddau@linuxcnc
- Thank you received: 29
31 May 2020 09:35 - 31 May 2020 11:58 #169498
by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic Nema 34 face plate
I have Chinese 34HS5802 motors 1600 Oz_in for my DIY CNC router. It is not reassuring
Last edit: 31 May 2020 11:58 by macsddau@linuxcnc.
- phillc54
- Thank you received: 2100
31 May 2020 10:01 #169499
by phillc54
Replied by phillc54 on topic Nema 34 face plate
I guess you would probably need a CNC thingy for that.Funny how no one suggested make a new one
- alkabal
- Thank you received: 52
31 May 2020 13:25 #169513
by alkabal
Replied by alkabal on topic Nema 34 face plate
Hi
You can't drill hole, do tread and add a custom adaptor plate ?
Br
Br
- Thank you received: 1482
31 May 2020 20:27 #169566
Replied by Todd Zuercher on topic Nema 34 face plate
3 of the 4 bolts should still, hold. I'd attempt to try to us it as is. Especially if you have the mounting recess milled with reasonably tight tolerances.
- kjames
- Thank you received: 3
01 Jun 2020 10:17 #169640
by kjames
Replied by kjames on topic Nema 34 face plate
Thanks all,
Yes, it is a 23 - I had my fingers one key too far to the right when typing
I did think about milling a new one, but I'm having a few backlash issues so once those are addressed..
I am currently using it as-is, the three bolts do still hold (just) - I'm using an extra nut on the face side to stand it off the mounting plate so I don't do the same again until I can get a mounting plate milled with a recess.. Hopefully it'll hold together.
If (when!) I get a replacement milled I'll post pictures up here
- Mike_Eitel
- Thank you received: 183
01 Jun 2020 11:46 #169654
by Mike_Eitel
Replied by Mike_Eitel on topic Nema 34 face plate
If you still able to mill, i thought you can not, you can make a 'plate' for the end of your motor and use long bolts/screws to additionally "press' the motor from his rear side..
Not beautiful bot probaby working.
Mike
Mike
Time to create page: 0.567 seconds
