I want to mill steel with this machine.
6 years 4 months ago #170353 by tecno
Replied by tecno on topic I want to mill steel with this machine.
Do you have anyone laser cutting close to you?
6 years 4 months ago #170384 by Marcodi
Replied by Marcodi on topic I want to mill steel with this machine.
I have but they are just asking so much money for any work.
6 years 4 months ago - 6 years 4 months ago #170385 by tecno
Maybe it just to bite the bullet if they can do what you want.
Last edit: 6 years 4 months ago by tecno.
6 years 4 months ago #170391 by bbsr_5a
Replied by bbsr_5a on topic I want to mill steel with this machine.
i only see VHM 6mm bit as a solution for the job
if you can clamp 8-12mm use Co8 7teeth that will do it even on plasma hole roughness
there are used VHM even TIAN on ebay less then 20Euros 5pcs that can be burned off
6 years 4 months ago #170426 by Marcodi
tecno wrote: Maybe it just to bite the bullet if they can do what you want.
Can't cause I am already buying a new ATC spindle. That is more important. I need to speed up my own things I produce.
So I also really want this table and having a router and a plasma CNC I really don't want to spend money on another company
6 years 4 months ago #170431 by Marcodi
Is this the type of endmill with inserts you guys were proposing to use to mill this?
Time to create page: 0.475 seconds
