Being this is my first try at this I would like to go through the MESA jumper and flash setup.
The PC I have is Optiplex 7020 with the onboard NIC and a second PCI NIC, 250SSD & 16mb ram onboard video.
Here are the Jitter #'s
Servo 1038813 max int 39327 max jitter
Base 59602 max interval 34602 max jitter
Not as good as I was expecting but ok.
Any ideas to lower these, I am willing to give it a try.
I have everything mounted on a test board with 12V & 5V going to each corresponding supply pins.
For the 7I94:
jumpers W3-up, W2-up, W4-down & w5 up to set the ip to 10.10.10.10 (connecting to the PCI NIC set to 10.10.10.6)
I need to mesa flash using the 7I94-7I89 config that was posted on a different thread.
The 7I89 I will start off with the default jumpers. I believe this should work with my 2000puls/rev quadrature encoders that I have. I will also have to set pin 41 on the 7I94 to true to see the 7i89 pins.
Out of Serial 1 & 2 of the 7I94 will be the 2 7I83's to run my servos and spindles.
Going to use default jumpers for the 7I83's.
Out of Serial 3 of the 7I94 will be the 7I90HD. Jumpers: W1-up, W3-up, W4-remove, W6-up. I know I need to mesaflash this so it will work with the serial input from the 7I94 and have all 3 50pin connectors be IO pins (to connect directly to the WRC relay IO boards) but I am unsure which one? Any recommendations? Can I flash this card thru the 7I94 or do I connect directly to the NIC to flash?
Out of Serial 4 of the 7I94 will be the 7I73 panel connector. Jumpers: W5-down, W6-Down, W7-Down (no keypad or LCD) W10-up, & W11-up. I did get 3-32count encoders for the 3 override potentiometers. I am planning to run my mpg to the 7I89 (its already wired that way) so I can add more buttons to my panel in the future if I want.
Is there anything that I missed or should do differently?
Thanks for the help!
