Bostomatic 400-2 Retrofit
5 years 2 weeks ago #223022 by nduerr
Replied by nduerr on topic Bostomatic 400-2 Retrofit
The options are getting sifted down!
PCW what are your thoughts on this config, similar to option 3 above?
1 7I80HD
1 7I48 Axis servo control w/ encoders
1 7I33 Spindle control
1 7I44 (8channel ethernet SSerial interface)
1 7I73 (front panel interface, SSerial)
1 7I90HD (OPTO22 interface, SSerial)
5 years 2 weeks ago #223028 by PCW
Replied by PCW on topic Bostomatic 400-2 Retrofit
I t should work but lacks some advantages
(analog out isolation, simpler cabling)
and is more expensive than my suggestion
5 years 2 weeks ago #223452 by JR1050
Replied by JR1050 on topic Bostomatic 400-2 Retrofit
I usually use a 7i84 for the operator controls, I think I used it because it has screw terminal blocks . have had issues trying to use analog pots for things like feed over ride, since you can’t exactly get the analog to digital conversion perfect, it eats up a ton of real-time cpu and lcnc doesn’t seem to function properly, that was the explanation that I had read in another thread. What is the pc control that you are removing?
5 years 1 week ago #223562 by nduerr
It was converted to MDSI OpenCNC (now Hurco) in the early 2000's. Both Bostomatic and the Integrator are out of business so no help there.
As far as I can tell with what testing I can do, the A to D board is working but the encoder board is not working, and they are so old that I cant find any used replacements. When I turn it on, all the axes run to their limits... so conversion it is!
5 years 1 week ago #223568 by JR1050
I would like to buy the mdsi stuff you have , are you willing to part with it? Do you have the original disks?
5 years 1 week ago #223578 by nduerr
Let me look. I think the disk had water damage when I got it. Are you looking for the boards also?
Time to create page: 0.254 seconds
