- Thank you received: 25
If you want to try RS232 , CNC should be in EDIT mode for Parameter upload or downloadThe RS232 port cable is connected in CNC Connector is a (M5). I keyed in the 0 to 900 parameters, I am still working setting the;
Ladder shows X21.4 input is OFF or Machine is in Emergency stop State. Just trace thisThis is a pic of the ladder logic that I currently have.
I do not think 269~274 required to set .As a separate issue, the attached pic named; "This explains the issue" at the bottom read 6) parameter 269 to 274 have no data, all 0s. The machine builder sent this document, I believe some data is needed, and may be related to the power issue. The file the machine builder provided does not have any data in this set of parameters.
I have reviewed the parameters that I have keyed in manually, all match the file from the machine builder. The question I wonder about, if I get to a point where a download from a PC works, will that over right if I am not correct about the data I keyed in so far.
Many, many thanks, all suggestions warmly welcomed.
