- Thank you received: 905
You can see in the driver's documentation that the maximum current is much lower. One is driving a 3.7 kW motor (200V) with a 7.5 kW Delta driver. It doesn't work well. An alarm is triggered under heavier load. I think you need a much larger driver.
I doubt it can do 50A, a 11KW Yaskawa does 45A, both are 200V parts, but i might be wrong, new stuff can handle a lot of power.
Assuming the Vevor VFD can output 50A (per spec), why would it be a bad idea not to just current-limit the VFD in parameters?
