No eBay APP ID and/or Cert ID defined in Kunena configurationThx for the comments.
I did see your post on the resolver and yeah I agree it seems best to go with an aftermarket encoder. The motor is from the early 80's, looks like this one: .
What did you mean by "cPCR are dc servo drives."
My overall approach was (for a hobby machine) to get a CNC machine and modernize over convert and manual mill and then with the CNC machine to try and set things up simple and replace the aging electronics (this is my first one of these). I've achieved that with the motion, relays, control boards etc, but this is proving tricky due to the complexity of electrical engineering of power loads/motion and potentially expensive components/upgrades involved (as the experienced people know, but hey I'm learning). I've documented my next step and thought process (more for me than anything) but also because you peeps are the only ones I know that get this:
1) [Budget] Three phase is expensive here in Aus, they charge consumption plus line rental (~$1000/year rental if you use it or not). I need to call the pwr company see if I can negotiate out of that, there will still be the connection fee etc.
2) [Motor dropped] The motor was running when I bought the machine but I had an accident with the motor while redoing the oil system, it fell and damaged the resolver plug. Fingers crossed the motor is ok but the resolver looks more intricate and the plug took the brunt of the impact and got minced. So if I go with the "use the existing drive" there's a risk it's dead in the water due to the resolver and it's not something I can test easily as I need 3 phase and fair bit of the machine to be moved to somewhere there is 3 phase outlet.
3) [VFD] The (cheap)VFD I bought aint up to the job.
3a) [Too small] for a single phase to drive three phase the current needed is way higher (3 wires worth of load over 1 wire). This is a case where buying based off kW only works if the phase's are matched, otherwise you've got to double (or more) the input rating (thx Tommy) .
3b) [Limited functionality] so can't control any of the key params/limits with this VFD. I think it's fine for a single to three phase load but not for speed controlling an older spindle motor control that has requirements that are not 240v/415v.
3c) Sounds like braking is going to cause me headaches (might be able to add a mechanical brake as a work around?)
4) Yaskawa got back to me (wow amazing service) and are looking into it based off what I've given them.
So where I'm at:
5) call up and confirm the 3 phase upfront and ongoing costs as this influences what I can test/buy/do.
6) suck it and see (aussie expression to accept the risks and try it out) with the existing VFD and motor and limit the spindle load (service life/braking/other issues? ). OR
7) hook up three phase and:
7a) try and repair the resolver and use the old driver. OR
7b) buy a 3 phase industrial VFD that I can control OR (costly)
Look at aftermarket motors (cheap -> v'costly [use the chinese VFD and a 3000rpm induction motor and various iterations up to an industrial unit])
In preference order I'm thinking of 5 then option 6, then 8, then 7b. That way I can start using it and spend the $$ to increase the usefulness of the machine based off actual usage/demand later on. (I'm assuming Yaskawa comes back and will confirm the current state based off the reading I've done and the collective knowledge here)
I'd love to know your opinions/thoughts and or any suggestions as to where I might be missing some knowledge or options or have got my details wrong.
