- Hardware & Machines
- CNC Machines
- Need Help! - X/Y motors all of a sudden chattering/struggling under no load
- besriworld
- Thank you received: 92
- Sray69
- Thank you received: 13
I know it happens with the X and the two Y drivers/motors. I am not sure about the Z because it is really hard to see with such slow/small movements. But I assume it is probably having the same issue.Does this happen with all drivers?
No. I am running an ethernet cable to a Mesa board.Running the machine with a parallel port?
- Thank you received: 7484
- smc.collins
- Thank you received: 139
check your RMS on A-A+ and compare to B-B+ so if that nets anything.
Tommys suggestion to check accelerations is a good suggestion as well.
- besriworld
The speed seems too low to be a problem in acceleration. What do you have for DIRSETUP DIRHOLD STEPLEN STEPSPACE
But the configuration worked... must be a wiring problem .Check for bad contact. Is the power supply one for all drivers?
- Sray69
Actually the problems is constant throughout the video. The sound fluctuates up and down and gets very concerning at times.I'm watching the video. Is the problem at 19-22 seconds?
I agree. This happens at ALL speeds and is constant. And yes it was working great before this started. The only thing I did different before this started was flipping the breaker off in the shop. I have no idea how or why that would cause this but that is all I can think of. Oh wait. I also added G61 to the beginning of my g-code for the first time ever right when this started, but I do not think that could be the cause. I took that out of my code and retested and the problem was still there. I will check all the things you guys mentioned and report back.The speed seems too low to be a problem in acceleration. What do you have for DIRSETUP DIRHOLD STEPLEN STEPSPACE
I have one PS for my drivers and one PS for my Mesa board.Check for bad contact. Is the power supply one for all drivers?
- smc.collins
- Sray69
No the machine had been shutdown for quite some time before shutting off the breaker.were the drives operating when the breaker was shut off ?
- Sray69
I then proceeded to check all the wiring in the CNC cabinet to be sure everything is seated well and tight. There were no wires loose at all. I then fired on the cabinet and LCNC. I checked the leads from the PS to the Drivers as recommended and they came in at .0068 volts at both ends. I then proceeded to run a test job so I could check things while it was running a job. I noticed right away that it was running normal again. I went ahead and checked the same leads while it was running and they came in at .0063 volts.
Based on everything I know and have done I feel like the problem is the 30A breaker in my shop sub-panel. Everything leads to it. I guess it is a good thing I had new one delivered today.
I really appreciate everyone that has jumped in to help me with this issue. Deciding to build a CNC instead of buying one with a support outlet is stressful when things like this happen. It is nice knowing where I can turn when I am stumped.
- Sray69
As mentioned previously I did do some testing on the PS's and checked all the wiring connections in the cabinet. There are no blinking or strange lights on in the cabinet. Everything appears normal.
I have attached my INI and HAL. I was hoping someone could look it over and see if there is something that could cause something like this?
- CNC Machines
