Decke Maho DMC100V Possibility of retrofitting
2 years 11 months ago #285071 by SOLD
7I95T config with 3x three phase PWMGens
File Name: 7i95t_tpwmd.zip
File Size:267.35 KB
Thank you for your support all the time.
I will test and report results soon.
2 years 11 months ago #285072 by SOLD
I have a Cincinnati Milacron lathe it came with Arca drives. I kept the 10hp axis and 60hp spindle motor and replaced the drives. If they are Brushed DC servos with tacho feedback, i'd suggest searching for Siemens simoreg or glentek pwm brushed drivers, they work good, can be had affordably used and will work with the mesa hardware.
Thanks for the great information.
But my motor is BLDC.
2 years 11 months ago #285107 by SOLD
File Size:267.35 KB
I just checked that the 7i95T in my stock has been sold. There is only 7i96s 5 pieces remaining I will order 7i95t again. When 7i77 is ready for sale
Now I'm trying to learn efinity software to use 7i95t_tpwmd as an example to modify it for use with 7I96S for testing only 1 motor While waiting to make the next order.
But it seemed like a difficult start to me. If you are free from work And without disturbing your time too much, I ask that you
Help create tpwm For 1 motor on 7i96S again
Thank.
2 years 11 months ago #285109 by PCW
I'm better setup to do this from work so I can do that Monday.
The following user(s) said Thank You: SOLD
2 years 11 months ago #285215 by PCW
7I96S firmware with one three phase PWMGen
(fault input on isolated input 10)
File Name: 7i96s_d1tp.zip
File Size:252.31 KB
2 years 11 months ago #285224 by smc.collins
Glentek offers BLDC drives, usually found in FADAL and other quality machines
Time to create page: 0.371 seconds
