Decke Maho DMC100V Possibility of retrofitting
2 years 11 months ago #285229 by SOLD
7I96S firmware with one three phase PWMGen
(fault input on isolated input 10)
File Name: 7i96s_d1tp.zip
File Size:252.31 KB
It was very fast support, thank you.
2 years 11 months ago #285230 by SOLD
I have a Cincinnati Milacron lathe it came with Arca drives. I kept the 10hp axis and 60hp spindle motor and replaced the drives. If they are Brushed DC servos with tacho feedback, i'd suggest searching for Siemens simoreg or glentek pwm brushed drivers, they work good, can be had affordably used and will work with the mesa hardware.
Thanks for the great information.
But my motor is BLDC.
Glentek offers BLDC drives, usually found in FADAL and other quality machines
Thanks, I'll try to find it.
2 years 11 months ago #285231 by PCW
File Size:252.31 KB
Well... fast but wrong that one has 3x PWMA outputs instead of PWMA,PWMB,PWMC
This should be closer:
File Name: 7i96s_d1tp...1-12.zip
File Size:254.01 KB
The following user(s) said Thank You: SOLD
2 years 11 months ago #285235 by SOLD
File Size:252.31 KB
File Size:254.01 KB
Thanks for double checking.
I'm starting to experiment with it now.
2 years 11 months ago - 2 years 11 months ago #285276 by SOLD
I configured it to be a spindle so I don't want to use Encoder feedback in testing Because the machine is not ready to turn on yet.
I want to view the signal from TB1-20,21 TB1-22,23 TB2-2,3 through measurement with an external oscilloscope. It's not successful yet.
Is there something wrong with Hal that I should fix?
Last edit: 2 years 11 months ago by SOLD.
2 years 11 months ago #285281 by PCW
Is the fault input connected?
is the 3phasepwm fault pin false?
Time to create page: 0.399 seconds
