Thank you for following.
Yesterday I experimented with an old device, it worked as per the clip, set it up like this, the motor can rotate.
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
#setp pid.s.error-previous-target true
net spindle-index-enable => pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---PWM Generator signals/setup---
#setp [HMOT](CARD0).pwmgen.00.output-type 1
#setp [HMOT](CARD0).pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
# ---TPPWM Generator signals/setup---
setp [HMOT](CARD0).3pwmgen.00.enable true
setp [HMOT](CARD0).3pwmgen.00.scale 3000
setp [HMOT](CARD0).3pwmgen.00.deadtime 5000
setp [HMOT](CARD0).3pwmgen.00.fault-invert 1
#setp [HMOT](CARD0).3pwmgen.00.frequency 20
net pwm.00-a bldc.0.A-value => [HMOT](CARD0).3pwmgen.00.A-value
net pwm.00-b bldc.0.B-value => [HMOT](CARD0).3pwmgen.00.B-value
net pwm.00-c bldc.0.C-value => [HMOT](CARD0).3pwmgen.00.C-value
net spindle-enable => [HMOT](CARD0).3pwmgen.00.enable
net spindle-vel-cmd-rpm => bldc.0.value
setp bldc.0.frequency 1
#setp bldc.0.value 0.5
#setp bldc.0.init true
#setp bldc.0.encoder-offset 0
#setp bldc.0.initvalue 5
#setp bldc.0.rev 1
#setp bldc.0.lead-angle 0
#setp bldc.0.poles 4
#setp bldc.0.scale 10000
I think this is incorrect.
It should be
net spindle-vel-cmd-rpm => bldc.0.frequency
Or maybe something else to control the speed.
