Mach3 machine, some questions.
- timo
- Thank you received: 61
12 Oct 2024 08:45 #311862
by timo
Mach3 machine, some questions. was created by timo
Hello,
I am hesitant to start, so I ask some questions instead. (some might feel rhetorical)
My Mach 3 machine works basically. Two things I am not happy with. a) missing hand wheel for jogging b) the rotary table c-axis that is mounted can only be moved, using a-axis. (did not find a way to change a-axis to c-axis.)
If I convert it to Linux I can fix those two things.
It is a x-y-z mill with open loop stepper system. A rotary table is fittet (could be a or c)
Questions:
Questions:
- Leave the running Mach3 alone?
- If I go for it:
- Just rip it all apart and start from scratch? Or leave it "Frankenstein" with parallelport?
- The old (still working) stepper drivers did not come with documentation and they use a ribbon cable for the signals. (so I do not really know what input pin is for what) Just throw them in the trash and use new DM860H drivers? (they are fairly cheap)
- The old machine has a big toroidal transformer with one PCB (I think that is the rectifier). The wires are labled 60V. Keep it or replace it with a new switching power supply?
- Thank you received: 7504
12 Oct 2024 09:15 #311867
Boot the PC from a USB with LinuxCNC, make a quick config while in LIVE mode, test the machine, edit the config and test some more, etc.
You do not need to install it for testing.
Replied by tommylight on topic Mach3 machine, some questions.
Oh hell no !Leave the running Mach3 alone?
- timo
12 Oct 2024 10:28 #311877
by timo
Replied by timo on topic Mach3 machine, some questions.
That is settled then
, the machine will get a Linux.
For installation I will just use a fresh SSD and install it properly, no point in messing with the live boot. The latency test is soso on the machine, but I think will do. ( I
What about the other questions?
As fate has it the driver for the y-axis released the magic smoke just when I tried to home the bloody thing.
not the first driver that dies, (not sure why they do this)
- Thank you received: 4155
12 Oct 2024 14:41 #311895
Replied by rodw on topic Mach3 machine, some questions.
Your toroid power supply is worth keeping. Assuming its 60v AC you can use a AC rated stepper drive. The Lam Technologies DS1076A is one such drive and arguably the best out there,. www.lamtechnologies.com/Product.aspx?lng=EN&idp=DS1076A
In fhe docs, there is an example of using a MPG with a parallel port. Some Mesa cards have dedicated MPG inputs, some need you to give up ome inputs to activate, but you can add additional I/O via a daughter card.
- timo
13 Oct 2024 03:09 #311939
by timo
I started ripping the electric apart yesterday. (damaged driver and Tommy tipped it)
- I do not really have any documentation for the brake out board and I wasted too much time with that thing already (fed up with it).
- One of the old stepper drivers is toast, considering how much the replacement costs it is not worth trying to investigate the pinout of a ribbon cable.
- Mesa 6i25 with a 7i76 plug and go kit is the way out. (in hindsight probably would have choosen one of the alternatives with network cable connection )
- strip entire electric
- probably set the system up on the workbench to get the control running without mechanics.
- give the machine a (very) rough clean up. (if some motivation kicks in)
- See if I should replace the electric cabinet.
- Thank you received: 426
09 Jan 2025 18:25 #318590
Replied by Cant do this anymore bye all on topic Mach3 machine, some questions.
Linuxcnc is way way better than Mach3
09 Jan 2025 18:42 #318593
I would have thought it was a typo, but seeing the post has been edited and that is still there, probably not a typo...
09 Jan 2025 19:09 - 09 Jan 2025 19:09 #318595
I'm gunna blame it on Goblins.
I've had my fair share of their input today.
Last edit: 09 Jan 2025 19:09 by Cant do this anymore bye all. Reason: Globlin attack
- timo
10 Jan 2025 09:35 #318638
by timo
Means the same to me! Trash means, it goes out the door. Separating things is very common here and it is easy to bring old circuit boards and such to the recycling companies. .-)
- timo
10 Jan 2025 09:49 #318641
by timo
Mach3 can obviously do a lot that I do not even immagine, same as Linux CNC.
Mach3 seems to be a dead end (obsolete hardware, obsolete software)
The Mesa Card is definitely better documented and I bought fairly cheap DM860 stepper drivers that seem to work (good enough for who its for).
This week I threw some of the equipment on the workbench and started messing with pncconfig.
Four motors are running The spindle drive is still an issue. (that ist next up)
Time to create page: 0.372 seconds
