Mach3 machine, some questions.
12 Oct 2024 13:45 #311862 by timo
Mach3 machine, some questions. was created by timo
Hello,
I am hesitant to start, so I ask some questions instead. (some might feel rhetorical)
My Mach 3 machine works basically. Two things I am not happy with. a) missing hand wheel for jogging b) the rotary table c-axis that is mounted can only be moved, using a-axis. (did not find a way to change a-axis to c-axis.)
If I convert it to Linux I can fix those two things.
It is a x-y-z mill with open loop stepper system. A rotary table is fittet (could be a or c)
Questions:
  • Leave the running Mach3 alone?
  • If I go for it:
    • Just rip it all apart and start from scratch? Or leave it "Frankenstein" with parallelport?
    • The old (still working) stepper drivers did not come with documentation and they use a ribbon cable for the signals. (so I do not really know what input pin is for what) Just throw them in the trash and use new DM860H drivers? (they are fairly cheap)
    • The old machine has a big toroidal transformer with one PCB (I think that is the rectifier). The wires are labled 60V. Keep it or replace it with a new switching power supply?
Greetings Timo
  • Moderator
  • Moderator
12 Oct 2024 14:15 #311867 by tommylight
Replied by tommylight on topic Mach3 machine, some questions.
Oh hell no ! :)
Boot the PC from a USB with LinuxCNC, make a quick config while in LIVE mode, test the machine, edit the config and test some more, etc.
You do not need to install it for testing.
12 Oct 2024 15:28 #311877 by timo
Replied by timo on topic Mach3 machine, some questions.
That is settled then :-), the machine will get a Linux.
For installation I will just use a fresh SSD and install it properly, no point in messing with the live boot. The latency test is soso on the machine, but I think will do. ( I
What about the other questions?
As fate has it the driver for the y-axis released the magic smoke just when I tried to home the bloody thing. :-) not the first driver that dies, (not sure why they do this)
12 Oct 2024 19:41 #311895 by rodw
Replied by rodw on topic Mach3 machine, some questions.
Your toroid power supply is worth keeping. Assuming its 60v AC you can use a AC rated stepper drive. The Lam Technologies DS1076A is one such drive and arguably the best out there,. www.lamtechnologies.com/Product.aspx?lng=EN&idp=DS1076A
In fhe docs, there is an example of using a MPG with a parallel port. Some Mesa cards have dedicated MPG inputs, some need you to give up ome inputs to activate, but you can add additional I/O via a daughter card.
13 Oct 2024 08:09 #311939 by timo
I started ripping the electric apart yesterday. (damaged driver and Tommy tipped it)
  • I do not really have any documentation for the brake out board and I wasted too much time with that thing already (fed up with it).
  • One of the old stepper drivers is toast, considering how much the replacement costs it is not worth trying to investigate the pinout of a ribbon cable.
  • Mesa 6i25 with a 7i76 plug and go kit is the way out. (in hindsight probably would have choosen one of the alternatives with network cable connection )
Plan for now:
  • strip entire electric
  • probably set the system up on the workbench to get the control running without mechanics.
  • give the machine a (very) rough clean up. (if some motivation kicks in)
  • See if I should replace the electric cabinet.
  • Platinum Member
  • Platinum Member
10 Jan 2025 00:25 #318590 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Mach3 machine, some questions.
Linuxcnc is way way better than Mach3
  • Moderator
  • Moderator
10 Jan 2025 00:42 #318593 by tommylight
I would have thought it was a typo, but seeing the post has been edited and that is still there, probably not a typo...
  • Platinum Member
  • Platinum Member
10 Jan 2025 01:09 - 10 Jan 2025 01:09 #318595 by Cant do this anymore bye all
I'm gunna blame it on Goblins.
I've had my fair share of their input today.
Last edit: 10 Jan 2025 01:09 by Cant do this anymore bye all. Reason: Globlin attack
10 Jan 2025 15:35 #318638 by timo
Means the same to me! Trash means, it goes out the door. Separating things is very common here and it is easy to bring old circuit boards and such to the recycling companies. .-)
10 Jan 2025 15:49 #318641 by timo
Mach3 can obviously do a lot that I do not even immagine, same as Linux CNC.
Mach3 seems to be a dead end (obsolete hardware, obsolete software)
The Mesa Card is definitely better documented and I bought fairly cheap DM860 stepper drivers that seem to work (good enough for who its for).
This week I threw some of the equipment on the workbench and started messing with pncconfig.
Four motors are running The spindle drive is still an issue. (that ist next up)
Time to create page: 0.148 seconds
