New ethercat / probe basic control for minimonster
1 year 2 days ago #337419 by ihavenofish
no documentation at all sadly
1 year 2 days ago #337420 by ihavenofish
so we have 8192 to 8203. all 0 except 8192 which is 6, and seems not writable. others seem writable but do not induce any change.
i have an idea: i will turn the drive back to panel frequency and run control and see if i can see anything change
1 year 2 days ago #337423 by ihavenofish
ding ding. so 8192 IS run/stop. goes from 6 to 1. which is true/false im almost positive.
But i don't have a way to write it. every write command says illegal data or address or function (different ones give different errors).
Do i need to tell it it is a true/false register, and not an int/float? if yes, how? i do not see any syntax for that.
thanks for all the help so far, i feel like were getting close, AND i also understand things better.
1 year 2 days ago - 1 year 2 days ago #337428 by ihavenofish
ok, sooo
function 3 reads a float and int (6 or 1)
function 1 reads a bit (true/false)
function 5 says illegal function (write coil)
function 6 says illegal data type
What is next to try? I rechecked the vfd settings, and its all "right". Also found out the params are registers (f0.04 = 0Xf004) so that neat. Not actually helpful though.
Last edit: 1 year 2 days ago by ihavenofish.
1 year 2 days ago #337430 by Hakan
Do you have a link to the manual?
Maybe there is something helpful in there.
1 year 2 days ago #337431 by ihavenofish
the manual is for a "slightly different" has no modbus information. my drive is called an HSD7000 and is a nearly identical clone of the innovance, but has modbus built in instead of on an add in card.
md380-inovance-manual.pdf
The add in card manual i am not sure is relevant
Communication Example; Configuration Of Rs485 Communication Between Drive And H5U - Inovance MD38TX1 Series User Manual [Page 50] | ManualsLib
Time to create page: 0.399 seconds
