New ethercat / probe basic control for minimonster
1 year 5 days ago #337313 by ihavenofish
can someone walk me through the setup on linuxcnc for this? i am seeing so many conflicting and incomplete instructions and components that are no longer supported or redundant (like vfdmod).
1 year 5 days ago #337314 by Hakan
Doesn't qualify as walk through but here are some hints. I used mb2hal.
forum.linuxcnc.org/10-advanced-configura...h100-inverter#335652
1 year 5 days ago #337315 by ihavenofish
Thanks. Problem is I don't really know what to do with this.
1 year 5 days ago #337318 by ihavenofish
Inching my way foreward.
Have a hal and ini for modbus now, and im getting an "out of range" error.
This happens if the drive in on or off, and im seeing no leds on the adapter. so perhaps the adapter is not enabled? Does it require a driver?
The chip on the adapter is CH340
1 year 5 days ago #337321 by ihavenofish
I found a hal and ini for a parker drive and commented out errors until it made it through and booted linuxcnc and had flashing lights on tx and rx. So we now have communication. Of course its all wrong cause its for a different VFD, but the communication is actually working.
Woo.
1 year 4 days ago #337366 by ihavenofish
This is proving difficult to debug. I get the same transaction error regardless of whether the drive is plugged in, however when it is plugged in, it does go into run model. So something is working. It will not however turn back off or respond to M3/m5 commands.
What should i be looking at next? :)
Time to create page: 0.155 seconds
